    Instant bugsplat when playing saved file
    3 Posts 3 Posters 595 Views 3 Watching
    • P
      phaidor
      When I 'open' a file that had perfectly-running animation when I 'saved' it, I nearly always get a 'bugsplat' as soon as I click 'play'. Thereafter, no amount of elimination and simplification will restore the model to any form of functioning animation until even an empty workspace crashes when I press 'play'. I'm using SU8 with SP3.2 on Windows 7 and most of my models are engines of various types. I've reloaded SU8 (several times), tried saving as SU7, tried 3D warehouse models and updated the graphics card. Still the problem continues! Suggestions earnestly requested!
      • GaieusG
        Hi Graham,
        I do not use SP but we have a dedicated subforum under the "Special interests" forum down on the forum index so I am moving your topic there for better attention.
        Welcome to SCF!
        • S
          sketchyKev
          I too have SU8 with SP3.2 on Windows 7, but don't have the exact problem you describe even with older models from Sketchup warehouse. What I do get, is that when I download a warehouse model it bugsplats the first time I try to run it, but if I double click on the model file with Sketchup closed, so that the file opens and starts a new instance of Sketchup at the same time, it runs 'perfectly', despite the warning messages that the file is an older version and may not work. Sorry I can not be more help, but I cannot replicate what you describe.
          Just curious, does this happen if you start with a empty file and create a very simple model such as a single SketchyPhysics cube falling under gravity?
