    Enable Web Inspector in WebDialog on Mac
    9 Posts 3 Posters 2.5k Views 3 Watching
      driven
      I've been trying to do this for ages, and it's so simple... just like me
      so, incase any other Mac users want the full native web inspector in SU, here's my 'how to'
      To enable the Web Inspector panel in WebDialog on Mac OSX...
      1. Go to ~/Library/Preferences/com.google.sketchupfree[n].plist
      2. Open the file with the Property List Editor.app(default) or other
      3. Click on the add [+] icon
      4. new item name "WebKitDeveloperExtras", then tab
      5. set type to boolean, then tab
      6. check box, sets this value to true
      7. open Sketchup, open a WebDialog, right click in a void and select "Inspect element" to open Inspector
            and it even splits off into separate window....
                   finally
                        john
      I haven't done extensive testing yet, but it's there...
      • Dan RathbunD Offline
        Dan Rathbun
        Sounds like a good candidate for a new chapter of the "WebDialog: Lost Manual" edition 2.
        ThomThom ?
        I'm not here much anymore.
          Dan Rathbun
          Would it be possible to set that from Ruby (and give Mac developers a toggle ?)
          if RUBY_PLATFORM =~ /(darwin)/
            require('sketchup.rb')
            module Dev
              MENU = UI.menu('Plugins').add_submenu('Development')
              module Safari
                MENU = Dev;;MENU.add_submenu('Safari')
                MENUITEMS = {}
                @@webinspector_enabled = false
                self.webinspector=(bool)
                  val =( bool ? "true" ; "false" )
                  @@webinspector_enabled =( bool ? true ; false )
                  Sketchup.write_default( "", "WebKitDeveloperExtras", val )
                self.webinspector?
                  val = Sketchup.read_default( "", "WebKitDeveloperExtras" )
                  return @@webinspector_enabled =( val == "true" ? true ; false )
                unless file_loaded?(__FILE__)
                  # init the var @@webinspector_enabled
                  self.webinspector?
                  puts("Safari Dev; Web Inspector enabled = #{@@webinspector_enabled}") unless $VERBOSE.nil?
                  MENUITEMS['Web Inspector']= MENU.add_item('Web Inspector') {
                    # toggle Web Inspector
                    self.webinspector=( !@@webinspector_enabled )
                  MENU.set_validation_proc(MENUITEMS['Web Inspector']) {
                    @@webinspector_enabled ? MF_CHECKED ; MF_UNCHECKED
              end # module Safari
            end # module Dev
          end # if Mac only
          file_loaded(__FILE__)
          You'll perhaps need to adjust the actual values written to the plist..
          if they are 0 || 1 for false and true, then change the val lines (15 and 22,) to:
          val =( bool ? 1 : 0 )
          and
          return @@webinspector_enabled =( val == 1 ? true : false )
          .. or similar. (you get the idea?)
            driven
            Hi Dan,
            been at a fete since i posted,
            what you don't get (which would be very useful) is the 'Develop' menu and it's down list.
            Can code add a new 'Main Menu' item for webkit to populate? or would I need to do that in the nib file?
            javascript debug and the console seem to work.
            I'll try and have a play later.
            john
              Dan Rathbun
              The code sample is a Ruby script that adds a submenu to the Sketchup "Plugins" menu (not to any Safari menu.)
              It may need to run at Sketchup startup in order to add menu items (at least on Windows submenus can be added after startup, but not menu items.)
                driven
                hi Dan,
                btw, cheers for your mac interest
                I can see what your code does for loading Web Inspector via ruby, but I don't think it needs a Plugins menu item or toggle. It's quite easy to do and undo manually.
                Anyone wanting to use WI in or out of SU needs Apple Developer Tools and if they can instal that, than this is a simple extra step.
                It's adding the other features associated with the Develop menu that's of interest to me. http://wn.com/Safari_debug_menu
                I'll see if I can set context menu items or shortcut keys to work with it, that may be easier than Menu Items.
                john
                added a link so you can see what I mean.
                • TommyKT Offline
                  TommyK
                  I am sure I am doing something stupid, but this isn't working for me.
                  I have found ~/Library/Preferences/com.sketchup.SketchUp.2016.plist . Opened it with Xcode, made the additional property to the root, saved it. Then nothing. I try to go back to open the .plist file again, and it doesn't let me.... Strange? Any ideas?
                    driven
                    Tommy, just set it as a global preference and it works for SU and Safari...
                    defaults write NSGlobalDomain WebKitDeveloperExtras -bool true
                    paste into Terminal or wrap in %x() from Ruby Console...
                    john
                    • TommyKT Offline
                      TommyK
                      john
                      YES! IT WORKS! SO SIMPLE! THANK YOU!
