    VisCAM View
    1 Posts 1 Posters 1.4k Views 1 Watching
      dedmin
      VisCAM View is a very easy-to-use and efficient tool to view, check, measure and communicate STL files.
      With VisCAM View you can visualise and check your 3D models in a very fast and efficient way. Errors like unconnected edges, flipped triangles, or unjoined solids are directly shown on the model. Cross-section views are available to inspect and analyse the model interior. Additional model information like dimensions, the surface area or the volume of the model can be retrieved at any time. An extensive set of measuring and annotation functions supports the analysis of model details and enriches the model with visual information. The annotated 3D model can be exported with the compressed VisCAM VFX format and exchanged with all other VisCAM products. Moreover the VFX file export allows you to reduce the STL file size by more than 90%.
      VisCAM View is available as freeware and is therefore best qualified to become your standard tool for STL file verification, data exchange and communication with your customers and colleagues.
      http://www.marcam.de/cms/index.83.en.html
