    Download files with a SketchUp plugin
    47 Posts 11 Posters 8.2k Views 11 Watching
    • I Offline
      ishboo
      @thomthom said:
      I really wish I understood the things required to compile correctly. I've compiled a couple of C-Extension, but only at the grace of TBD and AdamB who helped me out getting the setup to work. But I have no idea how or why... 😞
      Can anyone recommend resources to understand this?
      Once I wrap my head around this stuff, I will be writing up a few articles on the subject. I'll post links when I get them done πŸ˜„
      SketchUp plugin marketplace: http://extendsketchup.com/
      • tbdT Offline
        tbd
        ishboo: pull request sent. also added my 1.8.7 bundle in /build
        thomthom compiling is like a black box where you throw a bunch of files and expect another bunch of files. you need to know the parameters used (mostly how to include headers and libs and output formats) from the help files. also wikipedia entry on compilers is a good start for an overview.
        also use a file monitor [procmon(Win) and opensnoop(OSX)] when things go wrong - it saved me a lot of time when files were not found (looking in wrong directories) or wrong files were used.
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          Headers and libs are one thing. But it's all the paramters, the output format and compiler settings that I have no idea of how it works. I've tried looking for tutorials - but found nothing that made me any wiser. 😞
          • Dan RathbunD Offline
            Dan Rathbun
            ` %(#4000BF)[C:\Program Files\Microsoft Visual Studio 8\VC\bin>nmake /?
            Microsoft (R) Program Maintenance Utility Version 8.00.50727.762
            Copyright (C) Microsoft Corporation. All rights reserved.
            Usage: NMAKE @commandfile
            NMAKE [options] [/f makefile] [/x stderrfile] [macrodefs] [targets]
            Options:
            /A Build all evaluated targets
            /B Build if time stamps are equal
            /C Suppress output messages
            /D Display build information
            /E Override env-var macros
            /ERRORREPORT:{NONE|PROMPT|QUEUE|SEND} Report errors to Microsoft
            /G Display !include filenames
            /HELP Display brief usage message
            /I Ignore exit codes from commands
            /K Build unrelated targets on error
            /N Display commands but do not execute
            /NOLOGO Suppress copyright message
            /P Display NMAKE information
            /Q Check time stamps but do not build
            /R Ignore predefined rules/macros
            /S Suppress executed-commands display
            /T Change time stamps but do not build
            /U Dump inline files
            /Y Disable batch-mode
            /? Display brief usage message]`
            I'm not here much anymore.
              Jim
              The point is that you can do it from a Web dialog (via XMLHttpRequest), but sometimes you may want to check 'silently' whether something has changed on the web.
              In this case, the WebDialog could be opened outside of the visible area of the screen and sized to a minimum.
              wd = UI;;WebDialog.new
              wd.set_position(-1000, -1000)
              wd.show
              I think folks would welcome a simpler workflow without being asked where to save the file first. A single button to install/upgrade a plugin followed with a reminder to close and restart SketchUp.
                Plus, WebDialogs capture focus when they are displayed - which can be an annoyance if they pop up out of screen without the user' knowledge.
                  RonB
                  Is there a Windows build in sight?
                  • 3 / 3
