    Drawing an array of boxes
    15 Posts 3 Posters 1.4k Views 3 Watching
    • Z Offline
      Zane
      module Examples
      module SU
      module Structure
      require 'sketchup.rb'
      class Building
              def io_calcs
                      #distprompts = [$exStrings.GetString("What is the distance between
      the start of one column to the start of the next one? (make it at
      least 1m more than the width of the foundation")]
                      #distvalues = [5500]
                      # Now display the inputbox
                      #distresults = inputbox distprompts, distvalues,
      $exStrings.GetString("Distance between each column  (mm)")
                      #return if not distresults # This means that the user cancelled the
      operation
                      #coldistance = distresults
                      ##Enter values from C++ here
                      slab = IO.readlines('C;\\Users\\Zane\\My Documents\\slabout.txt')
                      $slabdepth = slab[0].to_f.mm
                      $slabwidth = slab[1].to_f.mm
                      $slabheight = slab[2].to_f.mm
                      UI.messagebox ("Sketchup will now take in the details and attempt to
      draw the building", MB_OK)
              def draw_slab
                      # Makes the process seem to be one rather than many; undo will undo
      the whole operation
                      model = Sketchup.active_model
                      model.start_operation $exStrings.GetString("Draw Slab")
                      #Adds model to the active entities collection
                      entities = model.active_entities
                      #Creates the object as a group
                      group = entities.add_group
                      entities = group.entities
                      #gives an initial location for the foundation
                      $slabwidth += $start_of_slab
                      #Creates an array of points for the base
                      pts = []
                      pts[0] = [$start_of_slab, 0, 0]
                      pts[1] = [$slabwidth, 0, 0]
                      pts[2] = [$slabwidth, $slabdepth, 0]
                      pts[3] = [$start_of_slab, $slabdepth, 0]
                      base = entities.add_face pts
                      # reverses direction of pushpull if incorrect.
                      $slabheight = -$slabheight if( base.normal.dot(Z_AXIS) < 0 )
                      # pushpulls object
                      base.pushpull $slabheight
                      # ends operation
                      model.commit_operation
              def draw_slab_array #need to do
                      $start_of_slab = 0.mm
                      draw_slab
                      wob = 30000.mm #not needed in the final one
                      wobt = wob
                      while ((wobt - $slabheight)>$slabheight)
                              $start_of_slab = $slabwidth + $slabheight
                              draw_slab
                              wobt = wobt - $slabheight
                      $start_of_slab = wob - $slabheight
                      draw_slab
      if( not file_loaded?("structureclasstestforstartpoints.rb") )
          # Adds a separator to the menu
              add_separator_to_menu("Draw")
          # Adds item inside the menu allowing a bit of code to be
          #carried out if clicked on
              UI.menu("Draw").add_item($exStrings.GetString("Test Structural
      Slab")) do
                      frame = Building.new
                      frame.io_calcs
                      frame.draw_slab_array
              file_loaded("structureclasstestforstartpoints.rb")
      end #Structure
      end #SU
      end #Examples
      1. Why is it that I need to create global variables for my program to
        say that the variable is recognised? Surely I can just use the
        variable anywhere in the class and it will work so long as it has been
        intialised before use?
      2. Do you guys see anything else wrong with the code?
      3. The code keeps looping in the while loop... help? (slabheight is about 7700)
      Thanks for your help guys!
        Cleverbeans
        There are only four points, so the only condition under which there would be repeated points are $start_of_slab == $slabwidth. If $slabwidth is 0 initially then when it's incremented it will take on teh value of $start_of_slab. Are you sure you didn't mean to type it $start_of_slab += $slabwidth? If you're using $start_of_slab as the initial position I expect that's the trouble.
        As for the variables there are more than one level of scope a variable can have. If you're not calling the Building.new method anywhere you're probably wanting class methods, which should read "def self.method_name" rather than just "def method_name", which will have access to class variables rather then using globals. Also, you cannot declare variables anywhere, if you're going to declare an instance variable it must be done within an instance method. There is some subtlety here between a class instance variable (not to be confused with a class variable) and a object instance variable which requires some care, since it's easy to declare it in the wrong location and get unintended behavior.
        Even better though, would be to get rid of the variables all together and use parameters and return values for your methods instead. This really helps when trying to track down where a bug is introduced since if the problem is with a global variable, every method that interacts with that variable has to be checked and it requires tracing all the method calls. If you've got parameters and return values you can verify each block independently which can save a lot of headaches. You can always put in useful default values, and array unpacking in Ruby is a really nice feature when you've got multiple return values like depth, width,height triplets. I don't see any explicit need to store the values as variables with the provided code, so maybe consider that approach if you can swing it.
        • Z Offline
          Zane
          I used Building.new and called the io_calcs function as well as the draw_slab_array function, what does that mean about my variables then, should I be able to use them within the functions that are in the class?
          To my knowledge, within a class, Ruby makes all of it's variables and functions public unless specified otherwise, so it confuses me as to why I get this problem of the variable not being read
            Cleverbeans
            Each kind of variable is referenced differently to indicate it's scope. @@var is a class variable, @var is an instance variable, and var without a modifier is a method variable. method variables can only be referenced within that method, instance variables have unique values for each instance, and class variables are shared by all instances of a class including super/sub classes. Class instance variables exist as well, and use the @var syntax, but are declared outside of a method which can trip up the unaware coder. They act like class variables but without super/sub classes having access to them. This gives you granular control over the scope for the reasons mentioned above - variables with limited scope are easier to debug. Using that as a rule of thumb then a best -> worst listing would be method -> instance -> class instance -> class -> global. In your case I believe simply changing the $ to @ would give you the behavior you're looking for assuming you want distinct values every time you call Building.new
            • Z Offline
              Zane
              Ahh i see, thanks for that πŸ˜„
              Another error now, the code keeps looping and doesn't stop (doesn't draw either), the values seem to be wrong also... nothing seems to be working :s
                Cleverbeans
                I would suggest breaking the code out into logical steps, and give each step a method. Normally I'd start with a blank file and write out what I want to happen in natural language as comments. Once I get it into a step-by-step form that makes sense I will declare method names around each step. Once I've done that I figure out what the inputs and outputs of each method should be and document them in a comment. Once that's done I pick the easiest one to test, write a simple test for it, then implement the method and see if it passes the test. Repeat until finished. It's hard to say why it's failing here because of all the variable kicking around, so maybe just try and split the methods into more bit sized portions then put it together at the end.
                • Z Offline
                  Zane
                  I think i've found it with the help you gave there (just a snippet of the code where the error might be):
                  class Building
                  	def io_calcs
                  		#distprompts = [$exStrings.GetString("What is the distance between the start of one column to the start of the next one? (make it at least 1m more than the width of the foundation")]
                  		#distresults = inputbox distprompts, distvalues, $exStrings.GetString("Distance between each column  (mm)")
                  		#return if not distresults # This means that the user cancelled the operation
                  		@slabdepth = slab[0].to_f.mm
                  		@slabwidth = slab[1].to_f.mm
                  		@slabheight = slab[2].to_f.mm
                  		#UI.messagebox ("Sketchup will now take in the details and attempt to draw the building", MB_OK)
                  It's either not taking in the values of slabheight, slapdepth nor slabwidth as i'm trying to take them in from an input file.
                  It's not even letting me "puts" the variables nor any other string I tell it to output like:
                  puts 'test'
                  Ideally i want to input variables from a text file whose content is
                  250
                  5500
                  7700
                  and assign each one of these values to a variable, then use those respective variables.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    The namespace Examples::SU I really intended for the Google supplied examples.
                    You should choose your own Toplevel namespace (Zane is good for now.)
                    Beneath that you will have you various plugin namespaces (module blocks.)
                    like this or similar:
                    module Zane
                      module BuildWizard # this plugin
                        module Structure
                          class Building
                          end # class
                          class Bridge
                          end # class
                          class Roadway
                          end # class
                        end # module Structure
                        module Widget
                        ebd # module Widget
                      end # module BuildWizard
                    end # module Zane
                    etc..
                    Once your namespace heirarchy is defined (in the first loaded file of your plugin,) you can break up the various code blocks into separate files (and save some indentation by using qualified blocks:
                    file2
                    module Zane;;BuildWizard;;Structure
                      # define module vars and module methods
                    file3
                    class Zane;;BuildWizard;;Structure;;Bridge
                      # define instance vars and instance methods
                    file4
                    class Zane;;BuildWizard;;Structure;;Building
                    file5
                    module Zane;;BuildWizard;;Widget
                    .. etc...
                    and use the require("filename") where needed to load the various files that make up your plugin project.
                    I'm not here much anymore.
                    • Z Offline
                      Zane
                      Sorry Dan, i'm a bit lost as to what you mean by your last post, why is it that I would split the file up into bits and what is the purpose of using modules, i've read they're similar to classes but nothing specified a distinct reason as to why they are as they are?
                      I'm also curious as to what you meant when you wrote module_function(:function) in the box.rb file, what does it do exactely? I presume it can only be used for external functions and not ones in classes?
                        Dan Rathbun
                        $exStrings is not YOUR object. It is a hash of strings, created and used by the Google supplied code examples.
                        Create your own local string, or a LanguageHandler hash object within your plugin namespace (DO NOTuse a global like Google did, it is bad programming.)
                        Or just use a string literal.
                        distprompts = ["Column Spacing"]
                        Also with a prompt string that large, the UI.inputbox is likely to look crazy.
                        • Z Offline
                          Zane
                          ok, thanks for the headsup on that, any idea about the crazy looping issue or why I can't see the puts anymore? Oh, and that module question, sorry there's so much to ask.
                            Dan Rathbun
                            Another booboo:
                            A UI.inputbox returns an Array, not a single value.
                            So to get the first value from an inputbox:
                            coldistance = distresults[0]
                            or
                            coldistance = distresults.first
                              Dan Rathbun
                              try stripping each line of whitespsce and control characters:
                              		@slabdepth = slab[0].strip.to_f.mm
                              		@slabwidth = slab[1].strip.to_f.mm
                              		@slabheight = slab[2].strip.to_f.mm
                              Eventually you'll want these values on one line separated by commas (likely with the tag "slab" as the first vaule.
                                lines = IO.readlines('C;\\Users\\Zane\\My Documents\\slabout.txt')
                                lines.each {|line|
                                  data = line.strip.split(',')
                                  if data[0]=='slab'
                                    @slabdepth = data[1].to_f.mm
                                    @slabwidth = data[2].to_f.mm
                                    @slabheight = data[3].to_f.mm
                                  elsif data[0]=='wall'
                                    # do something else
                                Dan Rathbun
                                @zane said:
                                Sorry Dan, i'm a bit lost as to what you mean by your last post, why is it that I would split the file up into bits ...
                                When you write complex plugins that have 1000s of lines of code, you WILL get tired of scrolling up and down. It is easier if you have a tabbed code editor to click another tab, find what you need in another file (a constant name, etc.,) and then click the tab of the file your working on. (I use Notepad++ which also allows splitting the editor into 2 panes.)
                                @zane said:
                                ...and what is the purpose of using modules, ...
                                See my info topic: [info] Using Ruby Modules
                                @zane said:
                                ...I've read they're similar to classes ...
                                Actually, class Class is the child subclass of class Module, and subclasses inherit objects (like methods,) from their superclass, so of course they are similar.
                                @zane said:
                                I'm also curious as to what you meant when you wrote module_function(:function) in the box.rbfile, what does it do exactly? I presume it can only be used for external functions and not ones in classes?
                                Well... you won't understand this issue until you do some reading... but basically the module_function() allows a coder to write a double-duty module, that can act as both a library module (it's methods are called from outside using name qualification,) and a Mixin-Module (that is mixed into classes, giving the class all it's instance methods.)
                                The box.rb is really a poor example of such a "double-duty" Module.
                                see Ruby Pick-Axe book: module_function
                                Jim asked a similar question, and I answered in the box.rb Example topic, see:
                                Re: module_function
                                Zane.. did you read my "Newbie's Guide" ? (If not click the Ruby Resource link in my signature.)
                                • Z Offline
                                  Zane
                                  Thanks Dan, I have read the pragmatic programmers book but that was a while back and unfortunately I have a deadline submission I need to meet next week, i've managed to get the C++ side of the coding done but am struggling with the Ruby and don't have time to re-assess what i've learnt, just need to sift through the relevant information and collaborate it.
