    My first bird table
    25 Posts 6 Posters 5.6k Views 6 Watching
    • G Offline
      Goonster
      Here is a couple of images of a slate roofed bird table I made. I`m really getting to enjoy woodworking in SU . Rendered using Shaderlight with a bit of post processing in Paint.Net.
      http://i530.photobucket.com/albums/dd349/G00nster/My Sketchups/SlateRoofBirdTable.jpg
      http://i530.photobucket.com/albums/dd349/G00nster/My Sketchups/BirdTablecloseup.jpg
        That looks pretty realistic. Better watch out or you'll have birds trying to get into your computer. πŸ˜„
        • G Offline
          Goonster
          Thanks Dave. I want to try a slightly more complex one next time. As I work in a garden center I get to see plenty of different styles and I can examine them close up. For example I noticed today that I made a mistake with this one. The braces at the bottom of the stand should be slightly narrower and not the same width as the feet. I`ll bear that in mind with the next one.
            Details, details.
            You should correct the wood grain direction on the feet and the diagonal braces as well as on the sides of the tray while you're at it, though. πŸ˜‰
            • jarynzlesaJ Offline
              jarynzlesa
              nice and realistic, good post process, agree with dave - repair texture mapping. good job πŸ˜„ .
              http://www.vizualizaceschodiste.mypage.cz/
              • KrisidiousK Offline
                Krisidious
                so you're saying that's not real? I had to study it...
                By: Kristoff Rand
                • david_hD Offline
                  david_h
                  shouldn't it read. . ."Home, Tweet Home?" 🀣
                  • G Offline
                    Goonster
                    I hadnt thought about the woodgrain. Good point Dave R. I suppose that would be achieved by rotating the various different parts when using the bucket tool . Its so obvious . Thanks for the tip.
                    Thanks jarynzlesa & Krisidious. I upped the bump map setting a bit when using Shaderlight on this one which I think helped a lot as well.
                    And of course - Home TWEET Home! Why did I not think of that. πŸ˜†
                      First of all, you need to separate the faces where it should go horizontally (otherwise the vertical faces would get a horizontal grain, too).
                      Then right click on a horizontal face > Texture > Position > right click again and > Rotate (90 or 270 degrees).
                      Once you are one with one face, just Press the Alt key when using the Paint tool (it will turn into a sampler) and sample the positioned material and go through all the other faces with the Paint tool (release the Alt key of course). It can be done in a couple of minutes.
                      The slanting part is similar - just there you cannot use the rotate command but grab the green pin while in texture positioning and rotate the texture by that.
                        As Gai says, you'll use Texture>Position>Rotate but it does require that you've applied the material to the faces and not just to the components/groups. If you apply materials without opening components/groups for editing, you won't have the option to rotate the material.
                        Also if, for example the diagonal braces are instances of the same component, applying the material to the faces of one, will cause them all to be painted. And if you change the axes so that they are aligned with the part, i.e. red axis along the length of the part, the material may go on cross ways as it did on some of the other surfaces but you'll be able to rotate 90Β° as you would on other parts because the material orientation will be relative to the component's axes.
                          True, I did not think of group/component materials. Looking at the model, the material could even be applied to them indeed.
                          • G Offline
                            Goonster
                            Thanks for mentioning that. I never realized you could rotate the texture.All this time Ive had SU and Im still learning new things. Ive been getting used to adjusting the texture on a quickly knocked up bit of wood . Ill try it out on the stand later. πŸ˜„
                              Remember the thing about changing the component axes on the diagonal pieces, too. There are other benefits besides ease of applying materials.
                              • G Offline
                                Goonster
                                Here are the revised textures -
                                http://i530.photobucket.com/albums/dd349/G00nster/My Sketchups/Revisedtop.jpg
                                http://i530.photobucket.com/albums/dd349/G00nster/My Sketchups/Revisedfeet.jpg
                                  Looks good. Not to bust your chops but you missed adjusting the material orientation on a face on the diagonal braces. Are you using a wood floor material? There's a horizontal line on the corner posts and it shows up on the foot as well.
                                  For the end grain you might make a copy of the material and then stretch it slightly, lengthwise only, and rotate it so it runs a bit diagonally. It won't be perfect but it will look more like end grain without much work.
                                  • G Offline
                                    Goonster
                                    I just checked the skp file again and I definitely adjusted all the faces. Youre right, I did use a floor texture though. Maybe thats what is causing the problem. Ill have to try a different wood texture , one thats not a floor texture.
                                      I guess there's not a lot of surface area but the parallel dark lines on the faces indicated by the arrows look like the long edges of the planks in the wood texture.
                                        Yes, this is it, much better. Just a couple of faces left to adjust the material on and it's a perfect model. πŸ‘
                                        • G Offline
                                          Goonster
                                          How`s this?
                                          http://i530.photobucket.com/albums/dd349/G00nster/My Sketchups/Feetfinal.jpg
                                            That's better. How about the feet? Did you draw them as separate from the cross pieces? Looks like the grain is running vertically on them.
                                            Most people probably have no good idea of which way the grain should run and wouldn't notice these sorts of things anyway.
                                            • 1 / 2
