    Bugatti veyron
    6 Posts 5 Posters 733 Views 5 Watching
    • I Offline
      imabzeous
      Downloaded This Model From 3D WareHouse.. rendered In keyshot..
      have comment plz
      • I Offline
        imabzeous
        I jut dont know one thing, i have applied the same material on both sides, but one is whitish an the other is greyish 😞 tied a lot but same results
        • V Offline
          Vicspa
          I've been wanting to use this car for a sample I was doing, and became curious as to the two tone look you are getting, so I did a quick sample in Thea, but lucky for me it looks fine.
          Sorry I'm not more helpful than this. If I had gotten the two tone look I'd be trying more in both SU, and my renderer.
          The warehouse has a few different Bugattis, by different names, try some other ones to see if that works for you.
          • N Offline
            notareal
            Perhaps back-faces that do mess keyshot result (With normal materials Thea handles back-faces gracefully, so issue might not be seen even the scene is same). Take a look on the model with the monochromatic view. If you see blue faces... time to inverse.
              That would be my guess, too. Not only the white is different but the blue is also darker on the "grey" half.
                Cyberdactyl
                I worked on a Veyron for many months here and there back in 2007 and 2008. Got maybe 80% done and so many other things came up, I never got back to it.
                http://img.photobucket.com/albums/v606/Cyberdactyl/BV1.jpg
