    Pause until action is complete
    12 Posts 5 Posters 1.3k Views 5 Watching
    • Z
      Zane
      Hey guys,
      Quick question for you all. I'm doing a system call for an exe file to be run in a ruby code and I don't want the ruby code to continue until the exe has finished running, is there any code or function I can use that will pause the script till the system call is complete?
      Thanks for your time and help!
      • mitcorbM
        mitcorb
        Hi, Zane:
        As a helpful suggestion, even though you may have recently joined, this question may be better posted in the Developer's Forum, due to the advanced nature of the question.
        • GaieusG
          Indeed so I have moved it (like anything that I cannot understand)
          ๐Ÿ˜„
          • Z
            Zane
            Ah ok, sorry for posting it in the wrong section
            • GaieusG
              Absolutely no problem. This is the very first post in the newbie forum:
              Subject: Welcome new SketchUp user!
              Hello there,
              Welcome to this little SketchUp Community we have set up here!
              Welcome to this forum for all your beginners questions. You may also have more advanced questions and may post them in the appropriate forum.
              If you're not sure if your question is beginner or advanced, then don't worry too much. The world is full of worrisome people already and we want you to get that cozy - de-worried feeling here. So in that case just post it here anyway.
              Well, the original was posted some 5 years now and "this little SketchUp Community we have set up here" has grown to be the biggest ever with 70K+ members now!
              ๐Ÿ˜‰
              • Chris FullmerC
                Hi Zane, do you have some way of knowing when the system call is done? Is there something that you can track that lets you know it is finished?
                All my Plugins I've written
                • Z
                  Zane
                  some text files will available for input is one thing that will be available after the system call
                  • Chris FullmerC
                    You could have your ruby search for those files every second or something (or less if it will be faster, or more if it generally is longer). Then once it finds the files, your plugin could continue. That could be an option.
                    • Dan RathbunD
                      Dan Rathbun
                      If your using system()
                      then the Ruby global $? returns the exit status.
                      If you have not yet used any subprocess during the current session, then $? will point at nil.
                      If you have then you can make a reference to the last Process::Status object referenced by $?, and do a comparison.
                      ` last = $?
                      system('somefile.exe')
                      if (last==nil && $? != nil) || $?.pid != last.pid
                      the system call finished
                      end`
                      I tried to get Kernel.trace_var to signal when $? changes, but it does not seem to work. ($? is a special read-only variable.)
                      I'm not here much anymore.
                      • Z
                        Zane
                        That's great! Thanks Dan and Chris ๐Ÿ˜„
                        • Dan RathbunD
                          Dan Rathbun
                          OK got trace_var workaround. Since system() returns true||false, we can assign the return value to a global var, and set up a trace exec string (or block if you wish,) on that global.
                          This example uses $done, but you will want to use a unique name for your global.
                          $done = nil
                          trace_var(;$done) {|var|
                            "puts('Subprocess #{$?.pid} finished with exit code #{$?.exitstatus}')"
                            # do other post system call code
                            untrace_var(;$done)
                            $done = nil
                          $done = system('somefile.exe')
                          You could even use a instance var instead of a global and a attribute setter method instead of the trace_var method:
                          module Zane
                            class << self
                            @done = nil
                            def done=(arg)
                              puts("Subprocess #{$?.pid} finished with exit code #{$?.exitstatus}")
                              if arg
                                # system() returned true
                              else
                                # system() returned false
                                # do some recovery code
                              @done = nil
                            end # def
                            end # class block
                            done= system('somefile.exe')
                          end # module Zane
                          EDIT: well I guess the instance var is not really needed unless you wish to store the return value for some reason.
                          • Dan RathbunD
                            Dan Rathbun
                            No problem, I fixed a mistake in the done=() method of the second example (above.)
