    Input and Output files in Ruby
    4 Posts 2 Posters 540 Views 2 Watching
    • Z Offline
      Zane
      Basically i've tried to do some research on this but I can't seem to get anything that is working in Sketchup so I really need your help guys, here is the problem i'm having:
      I have a text file in my documents which contain three numbers (they can either be seperated by spaces or by /n) and I want to have ruby read that file in line by line, storing each line as a new variable, the first variable being depth, the second being width and the third being length.
      Do you guys think you can help? I can show you what I mean in C++ if that helps:
      ifstream input("My Documents\\slabout.text");
      input >> depth >> width >> length
      input.close();
      Thank you for your help!
        Jim
        Hi Zane,
        You may want to check out Dan's reading a CSV file post.
        But in short and ignoring Exceptions and namespace issues, the core code might be similar to...
        # lines will reference a String including newlines.
        lines = IO.read("My Documents\\slabout.text")
        width, depth, height = lines.split("\n")
        Then, you will probably need to convert the values to Floats or Integers to make them useful...
        width = width.to_f
        Or reading each line..
        IO.foreach("My Documents\\slabout.text") do |line|
          # do something with line variable (String)
        • Z Offline
          Zane
          That's fantastic Jim, thanks!
          I just happened to stumble across something similar where I can use IO.readlines and arrays to sort out the writing in lines one by one.
            Jim
            Just another thought (while browsing around the forums..)
            depth = width = length = nil
            File.open("My Documents\\slabout.text") { |fp|
              depth, width, length = fp.gets, fp.gets, fp.gets
