    [code] Error raising scriptlets for testing
    1 Posts 1 Posters 1.2k Views 1 Watching
    • Dan RathbunD
      Dan Rathbun
      [ code ] Error raising scriptlets for testing purposes.
      Here's a collection of scriptlets that raise errors when you load them. They each only have one line of code:
      <span class="syntaxdefault">raise</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Exception</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"This is a test error raised by '#{__FILE__}'"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
      Load these scripts from one of your scripts or plugins, in order to test
      what happens when exceptions are raised.
      Helps you refine your rescue clauses, to trap all errors correctly. (I made them to test loading scripts from Ruby Console Plugins.)
      I have them in a subfolder called Plugins/test/error so you'll see the zip folder is named "error", but you can put the error folder anywhere you wish (ex: a subfolder named "Plugins/dev".)
      Each file is named after the exact Ruby Exception class, Ex: "SyntaxError.rb"
      error.zip
      I'm not here much anymore.
