    How come?
    2 Posts 2 Posters 560 Views 2 Watching
      Jibe1982
      Hello, I am really having troubles grasping the logic behing Sketchyphysics:
      I build a little mecanism which works, then I had a little something to it, without changing it and everyting fall apart, the joint connect to object without that I ordered it, evething is messed up. I would like to know if it's normal or if there is something wrong with my version of sketchup. I use sketchyphysics 3.1 with the version 7 of Sketchup, I tried to use the version 8 of sketchup but I really don't like it.
      COuld somebody please help me.
      Thank you
        Mr.K.1
        It's hard to say without seeing your model, could you upload it?
        But here are some known issues:
        • exploding/recreating a group will sever the connection
        • connections will only work on external groups
        • you can only connect one object to controlled joints(motor, servo, piston,..)
        • joints can only be one grouping layer deep
