    Really didn't understood gears
    3 Posts 3 Posters 748 Views 3 Watching
      AlainBo
      Hello,
      Doc talks about a window supposed to be displayed when I choose joints connection tool, click on the first joint then ctrl-click on the second.
      I never seen this window. I suppose it allows to define a gear ratio.
      Anyway, joints seem to be connected according to SP inspector but when I enter in simulation, joints make eratic movements.
      Any help?
      Regards,
        Mr.K.1
        I made a small model to demonstrate, try that if it helps you out:
        http://sketchup.google.com/3dwarehouse/details?mid=f19ddb8bb6180c86b3f2d40ad6ba6a7c
          sketchyKev
          When making gears the secret is making sure each joint is grouped with an object (not the same object) before using ctrl-click to make the gear connection. If each joint is not associated with its own grouped object the gear pop-up window will not appear. One you have made the connection, use the UI to inspect the first joint and the gear ratio parameter can then be changed in the UI.
