    [Code] Rantexpos
    9 Posts 3 Posters 3.4k Views 3 Watching
    • G Offline
      g.moggel
      hey guys. first up, i dont take credit for that plugin. its by axel lee. i found this plugin rantexpos at http://rhin.crai.archi.fr/rld/plugin_details.php?id=324
      it doesnt seem to work in su 8. can one of you look into it and maybe correct it? i'm not into coding but really need this to work.
      its supposed to randomize the texture position of the selected group/faces.
      code is as follows.
      def rantexpos
      	Sketchup.active_model.start_operation("RANTEXPOS!")
      	selected = Sketchup.active_model.selection
      	for ent in selected
      		if( ent.is_a? Sketchup;;Face )
      			tex = ent.material
      			texpoint = []
      			texpoint.push [rand(2048), rand(2048), rand(2048)]
      			texpoints = [texpoint[0],texpoint[1]]
      			ent.position_material (tex, texpoints, true)
      			ent.position_material (tex, texpoints, false)
      		if( ent.is_a? Sketchup;;Group )
      			for fac in ent.entities
      				if( fac.is_a? Sketchup;;Face )
      					tex = ent.material
      					texpoint = []
      					fac.position_material (tex, texpoints, true)
      					fac.position_material (tex, texpoints, false)
      	Sketchup.active_model.commit_operation
      filename="rantexpos.rb"
      if !file_loaded?(filename)
      	plugins_menu = UI.menu("Plugins")
      	if plugins_menu
      		plugins_menu.add_separator
      		plugins_menu.add_item("Randomize texture positions") {rantexpos}
      	file_loaded(filename)
      thanks in advance.
      • G Offline
        g.moggel
        thanks dan for looking into it. when starting sketchup i get an error now:
        "Error Loading File rantexpos.rb
        undefined local variable or method `filename' for AxelLee:Module"
        and still when i start the plugin from the plugins menu su crashes.
        greets,
        mo
        • Didier BurD Offline
          Didier Bur
          Typo: replace: file_loaded(filename) with: file_loaded(Filename)
          DB
          • Dan RathbunD Offline
            Dan Rathbun
            Parenthesized argument lists for methods. (And remove a few spaces when they were in between method names and arg lists. This causes an error in Ruby 1.8.6)
            Wrapped in a module.
            Added Constants at top for setting menus.
            <span class="syntaxdefault"></span><span class="syntaxcomment">#<br />#  rantexpos.rb<br />#<br /></span><span class="syntaxdefault">module AxelLee<br /><br />  </span><span class="syntaxcomment"># CONSTANTS<br /><br /></span><span class="syntaxdefault">  TOPMENU </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Plugins'</span><span class="syntaxdefault"> unless defined</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">TOPMENU</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># SUBMENU is blank to put on Plugins menu<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Enter a string in the quotes to create a submenu;<br /></span><span class="syntaxdefault">  SUBMENU </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">""</span><span class="syntaxdefault"> unless defined</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">SUBMENU</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  Filename </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">downcase<br /><br />module_function<br />def rantexpos<br />    Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"RANTEXPOS!"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    selected </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection   <br />    for ent in selected<br />        if ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            tex </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />            texpoint </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">            texpoint</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">([</span><span class="syntaxdefault">rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">)])<br /></span><span class="syntaxdefault">            texpoint</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">([</span><span class="syntaxdefault">rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">)])<br /></span><span class="syntaxdefault">            texpoints </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">texpoint</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">texpoint</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]]<br /></span><span class="syntaxdefault">            ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position_material</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> texpoints</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position_material</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> texpoints</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        end<br />        if ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            for fac in ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />                if fac</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                    tex </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br />                    texpoint </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">                    texpoint</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">([</span><span class="syntaxdefault">rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">)])<br /></span><span class="syntaxdefault">                    texpoint</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">([</span><span class="syntaxdefault">rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2048</span><span class="syntaxkeyword">)])<br /></span><span class="syntaxdefault">                    texpoints </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">texpoint</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault">texpoint</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]]<br /></span><span class="syntaxdefault">                    fac</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position_material</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> texpoints</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                    fac</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position_material</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> texpoints</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">                end<br />            end<br />        end<br />    end<br />    Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />end<br /><br /><br />if </span><span class="syntaxkeyword">!</span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Filename</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">topmenu</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">TOPMENU</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  unless SUBMENU</span><span class="syntaxkeyword">.empty?<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">=@@</span><span class="syntaxdefault">topmenu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_submenu</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">SUBMENU</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  else<br />    </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">=@@</span><span class="syntaxdefault">topmenu<br />  end<br />  </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Randomize texture positions"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault">rantexpos</span><span class="syntaxkeyword">}<br /><br /></span><span class="syntaxdefault">  file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Filename</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />end </span><span class="syntaxcomment"># module<br /></span><span class="syntaxdefault"> </span>
            I'm not here much anymore.
              Dan Rathbun
              Done. Edited the code.
              I did that in a secs just before bed. I have not tested it. (I assume it worked under Ruby 1.8.0, and didn't under 1.8.6 because of spaces between method names and argumentlists, etc.)
                Dan Rathbun
                I was able to get it to work on a simple model (attached.)
                SaucePan.skp
                I was also able to get a BugSplat! on a very complex old ver 7.1 model. I selected the terrian mesh, and tried it on that. (splatto!)
                • G Offline
                  g.moggel
                  hey man this is awesome. i needed to make a cutting board like ikeas whole-wood boards and they consist of individual parts glued together... anyway: NICE ONE!
                  although i have another thing. the textures original rotation is changed and completely oriented in the other way. is it possible to not let the rotation change or choose whether it randomizes rotation at a given angle?
                  thanks again, this was a big help 😉
                  greets,
                  mo
                    Dan Rathbun
                    I don't have time myself to work on this.
                    Um.. if you have control.. then it would no longer be random ? 😆
                    but I did notice that when I ran it on a pavement texture on a bridge model, that the roadway became misalign with the bridge. (Looked terrible.)
                    • G Offline
                      g.moggel
                      figured it out. i just need to rotate my face/object to be oriented with the axis. then i can hit rantexpos and it aligns them in the other way. thanks again for your help.
                      mo
