    Add_arc etc.
    26 Posts 7 Posters 2.9k Views 7 Watching
    • H Offline
      honkinberry
      Those are the values from the Arc in AutoCAD.
      If the Start is roughly 270 degrees, and the End is roughly 90 degrees, that is a D shape, not a C shape.
      Angles accrue in counter-clockwise fashion, yes? So from Start angle, one begins slowly spinning in a counter-clockwise fashion until reaching the End angle.
      --J
        Yea, it seems to be counter-clockwise - and then the C-shape makes sense. If you use the Protractor and uses the same angles to add guides, then adding then counter-clockwise from the X-axis places them exactly where add_arc draws the arc.
        • H Offline
          honkinberry
          I'm sorry, I'm just not following.
          I'm Susan, I'm standing at the origin, and I'm pointing at at object down the negative Green axis, at 270 degrees relative to me. It is a car, and it is driving in counter-clockwise circle around me. As it drives counter-clockwise towards a point located at my 90 degrees, the resultant path it drew was a D shape, not a C shape.
          I've dealt with arcs extensively with AutoCAD, and as I said, this is just taking the exact arc in AutoCAD and recreating here in SketchUp. But some of my arcs are getting reversed, and I can't figure out what I'm supposed to be accounting for.
          --J
            Right, I see.
            Maybe SketchUp normalize the start and end angle - because swapping the values around creates the same arc. ??
            You might have to use negative angles.
            • H Offline
              honkinberry
              Ah, I'm starting to get it.
              I made the same mistake when I was a 19 year-old programmer.
              If the arc crosses 0 degrees, it will get reversed.
              So you're right, Sketchup is sort of normalizing the arc. Or put more accurately, it's a bug -- it assumes the start angle to be less than the end angle.
              So easy enough fix -- if (start > end) start = start - 360.degrees
              Thank you sir!
              --J
                Probably be good to make a wrapper for the add_arc method.
                • 2 / 2
