    A way to avoid that ?
    29 Posts 6 Posters 13.8k Views 6 Watching
    • thomthomT
      @jim said:
      Couple a thoughts - terminate the message with a c language null: '\0' (just in case?)
      Isn't that just for strings?
      The string I pass is just a data buffer that will be filled with binary data - which one has to extract.
      @jim said:
      More obviously, you don't need to peek every loop iteration - so something like:
      refresh if (loop_counter % 500 == 0)
      Yes - more pragmatic than calculating time. I like it, it's KISS.
      • J
        Jim
        Yeah, I made an assumption the message was a c character array.
        • thomthomT
          No, it's a MSG structure. Just didn't bother to work out exactly how large it is. (probably will be making a wrapper for this.) So I just make a large buffer while I quickly tested it.
          ...if I don't need the returned message, would it be ok to just send an empty buffer?
          • Dan RathbunD
            Dan Rathbun
            @dan rathbun said:
            @thomthom said:
            Yes - as long as the operations a kept small it'll prevent whiteout.
            "whiteout" = "ghost window"
            ...[snip]...
            I would attempt to force a [PeekMessage](http://msdn.microsoft.com/en-us/library/ms644943(v) system call, for Sketchup's thread, within the "responding inteval" (can't remember offhand what it is.)
            So any way it's not your add entities block that needs to go inside a UI.start_timer proc, ... it's a API call to PeekMessage, like:
            begin
            >   peek = UI.start_timer(interval, true) {
            >    peek_window_msg()
            >   do_create_lots_of_model_entities()
            >   UI.stop_timer(peek)
            > end
            where, peek_window_msg() would be a method that sets up and makes the proper API call.
            @ThomThom & friends, ... I stumbled across where I saw the 'whiteout' interval.
            It's specified on the [IsHungAppWindow](http://msdn.microsoft.com/en-us/library/ms633526(v) Function reference page.
            Says 5 seconds.
            So perhaps:
            begin
              interval =( Sketchup.version.to_i<8 ? 4 ; 4.9 )
               peek_window_msg()
              UI.stop_timer(peek)
            I'm not here much anymore.
            • thomthomT
              Interesting - from that article.
              An application is considered to be not responding if it is not waiting for input, is not in startup processing, and has not called PeekMessage within the internal timeout period of 5 seconds.
              Though, it seems one can't reply on that time.
              The Windows timeout criteria of 5 seconds is subject to change.
              I have set the interval to a handful of times per second because I use it to force SU to update its statusbar.
              • Dan RathbunD
                Dan Rathbun
                I still wonder if a peek message loop could be written into the commit_operation API method.
                • Dan RathbunD
                  Dan Rathbun
                  And there is another 'nutty' thing that happens. When the ghost window is created, it has a different handle then the "real" application window. There are a couple functions that return the other handle, depending on which window handle you grab. (Strange that the IsHungAppWindow function is "not for general use.")
                  • thomthomT
                    I made a wrapper iterator that will take an enumerator objects and wrap it in between start and commit operation while updating the progress in the statusbar, kept alive by PeekMessage limited to a certain interval. Works really well for simple one-iteration operations.
                    • nikusknxN
                      nikusknx
                      Update for Sketchup 2014 :
                      require "Win32API.rb
                      msg = "\000" * 36
                      peekMessage = Win32API.new('user32','PeekMessage' , 'PLIII', 'I')
                      peekMessage.call( msg, 0, 0, 0, 0x0000 ) != 0
                      • 2 / 2
