    Accessing Menu Objects from Submenu's
    4 Posts 2 Posters 470 Views 2 Watching
    • D
      david.
      Is there any way to access a submenu's? I know I can access top level menu's via UI.menu( ... ). I've searched, but it appears there is no interface to access submenu's that I've added under the top level.
      • Dan RathbunD
        Dan Rathbun
        Sure there is, IF you are the one creating them.
        Just save a reference to the submenu instance. A module var works well. Constants can also work:
        PluginsTopMenu = UI.menu('plugins') PluginsSubMenuExporters = PluginsTopMenu.add_submenu('Exporters')
        I'm not here much anymore.
        • D
          david.
          Yes, I realized that. I thought there might be a way through the SU UI similar to accessing toolbars that have been created. Apparently, not. Not a big issue.
          • Dan RathbunD
            Dan Rathbun
            Actually the API lacks a Toolbars collection, which we have wanted. Now with the name method (just added, we can create one, 'on the fly'.)
            module SuchandSuch
              Toolbars={}
              ObjectSpace.each_object(UI;;Toolbar) {|tb|
                Toolbars[tb.name]=tb
            You refer to the just added method each which accesses the buttons ( UI::Command objects,) on a given toolbar.
            But ... the Sketchup::Menu class has not yet been updated with Enumerable methods (which should include each_item and each_submenu iterator methods;) nor any name, parent, etc getter methods.
            We'll have to cross our fingers for the next MR.
