    Connect & disconnect joint function?
    3 Posts 2 Posters 1.3k Views 2 Watching
    • H Offline
      hpnisse
      Hello!
      I got a few problems with scripted-joints in sketchyphysics.
      I've got the function that connect two objects to work, but not disconnect.
      This is the script that I use to connect two objects, and it work really good!
      ontouch{|toucher,s,p|
         if key("W")==1
                  connect(toucher,"fixed")
      But when I want to disconnect two objects thats connected with the script, it dosn't work.
      I know that there is a function that should do this, disconnect() here is the link, But I can't get it to work!
      So how should I do to create a disconnect script that can be trigger by a key or getVar command like the connect script?
      Thanks!
      ` /hpnisse`
      ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
        CPhillips
           if key("W")==1
                    @joint=connect(toucher,"fixed")
        #Then later.
        if(@joint!=nil)
           @joint.disconnect()
        • H Offline
          hpnisse
          Thanks so much! I've got it to work with that script!
          ` /hpnisse`
