    Fiddling with mass and breaking joints
    3 Posts 2 Posters 2.9k Views 2 Watching
      camokid11
      Try using more than 1 joint, eg, use 2 or 4 joins per wheel. and make the breaking strength bigger
      If you can read this, thank a teacher.
      If you can read this in english, thank a soldier.
        Mr.K.1
        @hpnisse said:
        You can change density of objects if you have SketchyPhysics3 [Download-link; http://sketchyphysics2.googlecode.com/files/SetupSketchyPhysics3x-Jun27.exe].
        In the UI panel there is a box named "Density" (standard value, 0.2). Cause "Density" is the same thing as "Mass", or am I wrong?
        /hpnisse
        Um, did no one notice CPhillips just recently published the newest SpetchyPhysics 3.1
        http://forums.sketchucation.com/viewtopic.php?f=61&t=31262
        It's about the same as SP3x-Jun27 but that was an experimental version, SP3.1 is fixed up with alot of new features.
        And mass is density multiplied by volume πŸ˜‰
          Mr.K.1
          Oh I see now, my bad, I was only looking at the last post date.
