    Has sk,phy. a time bar ?
    2 Posts 2 Posters 667 Views 2 Watching
    • T
      tonn
      I am learning sk.phy.
      Is there something look like a time scale bar ?
      Can I do this with any plugin?
      • P
        Physicsguy1
        Sketchyphysics does have a time bar - but it does not display the actual time that we are used, as in minutes, seconds, etc. It uses frames. Each frame is basically a set of data derived from calculations. You can see this feature on the lower left corner when a simulation is running.
        It might be possible to convert the frames into what we are familiar with. But that would require some calculations I am not at the moment familiar with. You can search through the Sketchup ruby code index for time functions and such, and see what you can do from there. Assuming you are familiar with coding in ruby.
        -Chris
