    WIP Kitchen
    3 Posts 3 Posters 585 Views 3 Watching
    • dermotcollD
      dermotcoll
      Mike
      Upper units too wide for a hinged door, grain running in wrong direction on the upstand at the back of the room and the spaces between the two doors at bottom left of the image is way too big. The corner wall unit at top left is also a bit odd looking. Good start but a bit more modelling needs to be done especially the oven housing unit! Keep going - you will get there.
      When you burn your arse - you gotta sit on the blisters!!
      • jo-keJ
        jo-ke
        I saw the colors and my first thought was dermotcoll πŸ˜‰
        nice start but I think there is still much work to do. The dimensions seem to wrong and the lightsettings are not OK
        http://www.zz7.de
        • soloS
          solo
          Mike,
          I agree with Dermotcoll on the upper cabinet size thing, as well as lower cabinet size as it needs to open and clear island, looks like they will be too large as well as causing an obstruction, besides being against code. Why not have them slide instead? that way you can keep the over-sized look. The upper cabinets also look too high, whats the distance between counter-top and cabinets?
          http://www.solos-art.com
