    Inputbox prompts by variable
    3 Posts 3 Posters 361 Views 3 Watching
      Andreas
      I have a problem once again .
      This code works well:
      prompts = ['What is your Name?', 'What is your Age?', 'Gender']
      defaults = ['Enter name', '', 'Male']
      list = ['', '', 'Male|Female']
      input = UI.inputbox prompts, defaults, list, 'Tell me about yourself.'
      Now I want to give the information by variable.
      For example for 'prompts':
      p = "'"What is your Name?"'" + "," + "'"What is your Age?"'" + "," + "'"Gender"'"
      prompts = [p]
      But that don´t works!
      What is my mistake?
      Is there another way to solve the problem?
      Or is that not possible?
      With best regards from Germany
      Andreas
      • honoluludesktopH Offline
        honoluludesktop
        Here are three lines out of one of my programs:
        ` prompts=["Help options: ","Import unit: ","Select origin: ","Polylines: ","Materials: "]
        enums=[update_this, units_list, model_selection, convert_selection, import_texture]
        results=inputbox prompts, a_values, enums, my_file_name+" Options"`
        I have never tried what you seem to be attempting.
          Jim
          In the first example, prompts is an Array of Strings, which is the correct form.
          In the second, p just a String; so when you write prompts = [p], y0u get an Array containing a single String.
          p = [] p << "What is your Name?" << "What is your Age?" << "Gender" prompts = p
          Do not use p as a variable. Although it does work, p is a shortcut for the .inspect method.
          p prompts is the same as puts prompts.inspect
