    MiniTest Testing Framework for SU
    1 Posts 1 Posters 280 Views 1 Watching
    • P Offline
      Pierreden
      For those interested, heres what you need to be able to use Ruby 1.9 new unit testing framework in SU.
      1. Download and unpack into su plugin folder
      2. require "minitest/autorun" at the beginning of the script you want to be testing
      3. load /require all modules/classes and testing files in you script
      4. Run MiniTest::Unit.new.run at the end
      5. Unit testing magic!
      It should look something like this:
      require 'minitest/autorun.rb'
      class A
      	def say_hi
      		return "Hi!"
      class AClassTests < MiniTest;;Unit;;TestCase
      	def setup
      		@a = A.new
      	def test_say_hi
      		assert_equal @a.say_hi, "Hi!"
      MiniTest;;Unit.new.run
      And Output something like this in the console:
      Run options; --seed 27422
      # Running tests;
      init
      Finished tests in 0.047000s, 21.2766 tests/s, 21.2766 assertions/s.
      1 tests, 1 assertions, 0 failures, 0 errors, 0 skips
      To run it again, just run load "yourloadfile.rb" in the ruby console.
      Im not able to get the MiniTest::Unit::autorun feature to work, and this script will run ALL tests loaded into SU, but its seems more than good enough for most.
      Regards
      Pierre
