    Programing menu icons
    3 Posts 2 Posters 331 Views 2 Watching
    • honoluludesktopH
      honoluludesktop
      Can anyone point me to very simple examples of menu icons, and tell me what to look for. The following is the code used for my menus, is this where I begin to add code to set up the use of icons?
      unless file_loaded? File;;basename(__FILE__)
        add_separator_to_menu("File")
        UI.menu("File").add_item("Select Component") {hdt_sel_comp}
        file_loaded File;;basename(__FILE__)
      • Didier BurD
        Didier Bur
        If you mean a toolbar, here is a typical code block:
          arcs_tb = UI;;Toolbar.new("Arcs")  #declare the toolbar object
          cmd = UI;;Command.new(("Arc-Circle; 3 Points")) { Arc3pts.tool } #create a new command object 'cmd' that launches the tool within the {}
          cmd.small_icon = "3parc2.png" #set this new command a small icon image (users sets this in the preferences dialog)
          cmd.large_icon = "3parc.png" #set this new command a large icon image (users sets this in the preferences dialog)
          cmd.tooltip = "Draw an arc or circle with 3 points" #create a tooltip when hovering the icon
          arcs_tb.add_item(cmd) #add the command 'cmd' to the toolbar object
        You can put the toolbar code (for instance) after your menu settings:
        if (not file_loaded?("myScript.rb"))
        menu = UI.menu("Plugins")
        my_menu=menu.add_submenu("my submenu label")
        my_menu.add_item("Here we go !") { cmd_to_launch }
        arcs_tb = UI::Toolbar.new("Arcs") #declare the toolbar object
        cmd = UI::Command.new(("Arc-Circle: 3 Points")) { Arc3pts.tool } #create a new command object 'cmd' that launches the tool within the {}
        DB
        • honoluludesktopH
          honoluludesktop
          Didier, Thanks, This will speed up access to one of my tools.
          Addenda: Wow, that was too easy to do.
