    Frame Rate, Gravity, and World Scale
    2 Posts 2 Posters 1.5k Views 2 Watching
      mptak
      Has anyone seen or found a good description of just how the physics setting variables work. Just how would I set them if I in fact wanted to mimic as closely as possible the "real world" at either 15 or 29.4 frames per second. I am quite happy to tweak but would like to build on the work of others as I try and work a Vulcan mind meld between Algodoo....Sketchy Physics...and dare I say it....the physical world. Any insights greatly appreciated.
        CPhillips
        I am afraid that isn't right. Think of it this way. 1 is slow mo, 3 is normal speed and 6+ is fast forward.
        The framerate is the number of physics steps that happen before Sketchup displays the frame. A physics step is 1/60 of a second. The default is actually 3 and with it goes like this
        Advance physics simulation by 1/60 sec.
        Update Sketchup object positions.
        etc.
        if the framerate is 1
        etc.
        Here is where it gets a bit tricky. By far the slowest part of this cycle is the Update Sketchup Object part. That means that the lower the framerate the slower the model appears to run even tho its actually running at the same speed as if you were using 3. With 3 you will just get more simulation time in the same number of real time seconds.
        Hope that helps.
        Chris
