    Transformation scale
    2 Posts 1 Posters 410 Views 1 Watching
    • P Offline
      Pout
      Here is what i want to do:
      Scale an object in Z
      Seems simple but the whole points-geometry-transformation thing is not always very clear to me
      I know if i want to scale the first selected object 50% in z then this is the code:
      new_transformation=Geom;;Transformation.scaling thepoint,1,1,0.5
      select[0].transformation=new_transformation
      Now, thepoint, should be the base point of scaling (I think). Which should be the center point of the bottom face of the bounding box.
      I found this script to determine the center point of the top face of the bounding box:
      bb = Geom;;BoundingBox.new
      bb.add(select[0].bounds) if select[0].respond_to?("bounds")
      xmin=bb.min.x;ymin=bb.min.y;xmax=bb.max.x
      ymax=bb.max.y;zmin=bb.min.z;zmax=bb.max.z
      apex=Geom.linear_combination(0.5,[xmin,ymin,zmax+2],0.5,[xmax,ymax,zmax+2])
      Credits to who-ever wrote this!
      When I use that I suspect the entity should be scaled 50% upwards (since i use the top center point) and that the entity stays on the same spot.
      But somehow it moves to the origin. (with the 50% upwards scaling)
      What don't I understand?
      • P Offline
        Pout
        ok i've found it here: http://forums.sketchucation.com/viewtopic.php?f=180&t=24947&p=213942
        use .transform! instead of .transformation
        .transform adds the specified transformation to the already existing one
        .transformation replaces the current transformation (like in: will put the object back to 0,0,0)
