    A few lab cabinet images
    5 Posts 3 Posters 755 Views 3 Watching
    • G Offline
      Glenn at home
      Hi all, I thought I would finally share a few images. Here are a few sections of some lab cabinets we make here at work. Nothing too detailed just some images I made for a customer.
      Modeled from AutoCAD output and edited in SU.
      http://lh4.ggpht.com/_qYm9iYJhU7w/TI47KWUwlJI/AAAAAAAABzc/onlsYB93sRQ/s800/Lab Section small.jpg
      http://lh3.ggpht.com/_qYm9iYJhU7w/TI47KShD4iI/AAAAAAAABzY/esvYetc84x4/s800/Lab Section 1 small.jpg
      • boofredlayB Offline
        boofredlay
        And the render engine you used???
        Nice work Glenn.
        • dermotcollD Offline
          dermotcoll
          Nice cut-away image Glenn. Do you make the door from melamine faced chipboard as well? Man that is tight budget stuff!
          Is the base just used as a service void ? And what are the clips on the interior of the base? Click fittings? Many questions - very curious!
          Really like the point of view and the detail being shown, very interesting.
          When you burn your arse - you gotta sit on the blisters!!
          • G Offline
            Glenn at home
            Nice work Glenn.
            Thanks Eric, that was the Vray demo.
            • G Offline
              Glenn at home
              Thanks. Yes the door on this is the same as the panels. We can do HPL doors and drawer fronts if the customer wants it but they still will be PVC edge banded (like the panels). The clips are Keku clips as that chase is a service void. Used for med-gas and water supply and drains. I did a render showing a typical base unit and wall unit with hanging rail. I'll put those up after while.
