    Render + Fotosketcher
    5 Posts 3 Posters 686 Views 3 Watching
      rcossoli
      hello all, I too am testing this program FotoSketcher and I like many results.
      Here is a picture made to put together a rendering (vray) and an image generated FotoSketcher, this is the result.
      C & C are welcome
      Greatings
      http://img824.imageshack.us/img824/6739/1autosketcher.jpg
      Fotosketcher
      http://img265.imageshack.us/img265/7008/2render.jpg
      Render (vray)
      http://img683.imageshack.us/img683/4579/3autosketcherrender.jpg
      Fotosketcher + render
      THREEDIMENSIONSWEB dot COM
        Ross Macintosh
        rcossoli - I like your combined image. When you combined you managed to minimize the lines from your Fotosketch version. That's good because in it they were really heavy. I'm not a fan of how fotosketcher & other filter-based manipulations draw lines at the found edges -- they seem unnatural to me.
        I hope you don't mind that I attach a simple watercolour created from your VRay render. I find the watercolour results from fotosketcher significantly better than any other filter-type software I've tried or seen. I think the fotosketcher watercolour results are very presentable. It would be interesting to see how they'd look printed onto watercolour paper.
        Regards, Ross
        rcossoli VRay image processed by FotoSketcher
        Here's the fotosketch watercolour settings I used
          rcossoli
          Thanks for the advice and settings!, The truth is very good your example.
          Actually I was trying to give a different appearance to render, try to score more edges to remove a bit that hard look of render.
          I prefer the truth renders over another type of presentation, this is a good way to play with that and go a little further.
          This is a very appealing because there is a lot of personal preference in the middle, not as technical as a render.
          • F Offline
            fymoro
            I relly like your third image, and the Vray render is really nice too, and what a model!!! Congrats...
            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
              rcossoli
              Thank you and the model still needs more work, not quite finished, but if I can say that I have a lot of work, especially going to design the details as models.
