    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    SketchUp 8 Bugs & Troubles!
    25 Posts 8 Posters 3.6k Views 8 Watching
    • Chris FullmerC Offline
      @dan rathbun said:
      If I face away from the computer does it work correctly ? πŸ˜›
      That depends on which hemisphere you are in. I think that is accurate for the northern hemisphere, but in the southern, you might also need to stand on your head. πŸ˜„
      All my Plugins I've written
        I find scarifying a chicken to give good results.
        • Dan RathbunD Offline
          Dan Rathbun
          I didn't know you were a sadist, Thom.
          http://dictionary.reference.com/browse/scarifying
          I'm not here much anymore.
          • bradB Offline
            brad
            I can respond to the Construction Line Stipple issue. I have verified the custom line stipple patterns worked in SketchUp 7 and not in SketchUp 8. I'm not sure if the integer value for the Stipple patterns have changed or not. If and when I find out I will respond here. I have logged a bug in database about the stipple problem, thank you.
            Brad
            SketchUp QA
              Jim
              Thanks Brad! As far as I know, only the 4 stipple types have been documented. If other types are supported, it would be great to get those documented and to be able to use them.
              • 2 / 2
