    Plugin for Sketchup using VB.NET or C#
    7 Posts 5 Posters 10.2k Views 5 Watching
      LSeibt
      Hello everyone
      I wonder if someone has already developed a plugin for Sketchup using VB.NET or C#.
      I saw that I add as a reference library of Sketchup as a COM
      But I found no example of coding in these languages over the Internet
      Could anyone help me with this?
        morisdov
        Hello Leonardo,
        I created a few for customers.
        1. Using visual studio create a new project type of a windows class library. In your dll expose public methods to be accessed from sketchup.
        2. download from the web win32api.so and copy it into Sketchups Plugins folder. follow the examples on http://ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html
        Start slowly and advance in steps.
        Moris
          Jim
          We've had a few members post some VB-related files on the forum in the past. I'm not sure if these are of interest, but here are the posts:
          [1] http://forums.sketchucation.com/viewtopic.php?f=180&t=23441&start=0
          [2] http://forums.sketchucation.com/viewtopic.php?f=180&t=22828&start=0
            LSeibt
            @morisdov said:
            Hello Leonardo,
            Moris
            Actually what I had thought was to develop something directly in VB.NET that "converse" with Sketchup.
            I add in my project the COM "Sketchup 2.0 Type Library" which gives me access to the API commands SketchUp.
            I tried using the code that follows, but it always shows an error saying that the class is not registered.
            Imports SketchUp
            Public Class Form1
                Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
                    Dim app As SkpApplication = New SketchUp.SkpApplication
                    Dim doc As SkpDocument
                    doc = app.ActiveDocument
                End Sub
            End Class
              jhauswirth
              @lseibt said:
              [/code]
              You need to register it-
              regsvr32 sketchupreader.dll
                LSeibt
                @jhauswirth said:
                @lseibt said:
                [/code]
                Even registering this DLL can not run this code
                Did you already wrote some code to Sketchup using VB.NET?
                Have some simple example that could show?
                • P Offline
                  Pout
                  i'm not into the dll stuff, but i'm currently working on communication between Sketchup and Microsoft PowerPoint and Microsoft Project.
                  Win32OLE.so can be used in that case
