    Downtown street scape improvements
    25 Posts 10 Posters 4.0k Views 10 Watching
    • F Offline
      flynbrians
      Here are some low res renderings of a project I did working with the Civil engineers and Landscape Architects. Comments and suggestions are always welcome! I normal use Podium to render and this time the model was too big so at the last minute i had to learn V-ray. Not too bad with only a few hours to learn.
      SU->VR->PS
      Thanks for looking 😲
      • Chris FullmerC Offline
        Thats good looking stuff. Is that overlaid onto a Google Earth groundplane? Do you have an estimate how long it takes you to do each one?
        And what town is this for?
        Chris
        All my Plugins I've written
        • F Offline
          flynbrians
          The city is Oak Harbor WA. I will post some before pictures. I looked at using Google earth for the back grounds but it just did not work out right. It looked too fake, flat etc. I have used it in the past for other downtown street scape renderings where the buildings are taller. The background is made from a TOPO survey that I then translated into a 3D tin model. This base has all the existing line work for the curbs, storm drainage and all the other physical features. Then I take the proposed 3D roadway and alignment. Typically i get them or develop them from Civil 3D. (by the Civil Engineers my background is Civil Design) This is a great way to make sure my model is exactly what was designed!
          The model is about a mile and a half to two miles long. It is pretty impressive and i had to make sure and keep the face count to a minimum. I have 8 shots of the proposed roadway that were chosen by the Civil engineers and the city. I would estimate around 90-100hrs for the project. I would like to keep tweaking the materials and playing with V-ray but the timeline has passed and this is the best i could do with the time i had. I might also post the kmz file.
          my company is http://www.apexcontractingwa.com if you need any design viz services.
          existing 2-way street
          • F Offline
            flynbrians
            Any comments would greatly be appreciated!
              Dragoonprogramming
              I have been to oak harbor this is top notch!
              I love all the little details, The street work is also good!
              "...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
              My website http://dragoonprogramming.weebly.com/
              • jo-keJ Offline
                jo-ke
                very nice model. I would darken the sidewalks, they look to clean and to light
                http://www.zz7.de
                • mitcorbM Offline
                  mitcorb
                  I would say maybe tweak the sidewalks, too. But I like the vibrant color quality of the images. It really seems to work with this environment.
                  • W Offline
                    wyatt
                    Can you explain the process of using Civil 3D for these images? Do you actually use Civil's assemblies as part of this model? I use a similar process of importing linework from CAD, but I have not imported a plan and profile, which I think is what you are describing.
                    Nice images overall. It appears, especially in image 1, that the cars are out of scale or that stretch of road was intended to be a one-way street.
                    • F Offline
                      flynbrians
                      The proposed roadway is a one way street to allow for more pedestrian access and angle parking. The roadway width is wide at the corner at the beginning of the project to allow for freight deliveries. This has to meet WB-40 turning movements.
                      On a project like this where parking, ped ramps, driveways and landscaping are vital to the property owners I chose to use the final TIN surface from the proposed roadway and sidewalk assemblies. Although Civil 3D is not the best to use in downtown environments it is still great for being able to have the vertical profiles and assemblies dynamically linked. I can then overlay the 2D Civil line work, from the illumination to the landscapeing and keep them updated quickly by importing the DWG directly into the model.
                      You can actually import the completed assemblies into SU. The catch is you must export them to a dwg and you must export them as ACIS solid. you do not want them to be exported as a poly mesh.
                      Thanks for the comments!
                      • F Offline
                        flynbrians
                        Thanks for the comments. Has anyone had much experiance rendering large outdoor scenes? I am trying to nail down the best rendering app and have used V-ray and Podium. I like V-ray but I don't like the price tag. V-ray set up is alot like 3dSMax.
                        Thanks again!
                        • F Offline
                          flynbrians
                          😲 The rest of the final renderings. 😲
                          • F Offline
                            flynbrians
                            Just wondering if anyone has had much experience with VRay? This was the only project I have used it on and it is time to pay up for Podium or get V-ray. I am honestly not complaining about Podium but it is not as detailed as V-ray and IMO it does not have the realistic quality for the renderings.
                            Thanks!
                            • KrisidiousK Offline
                              Krisidious
                              fantastic work... I would love to see this rendered in Vue...
                              By: Kristoff Rand
                              • F Offline
                                flynbrians
                                Thanks for the complement.
                                Do you use Vue? I don't even know anything about it and Google did not bring anything up. I have not seen any discussions on what most are using and why? I know there is large differences between rendering environments for exterior and interior.
                                I think each user should add there rendering application along with the version of SU and CPU. Just a suggestion.
                                  lucifer1101
                                  Vue is a landscape modeller mostly and can handle large scenes with many objects and details..
                                  I would suggest getting a demo or the PLE it is well worth trying out.
                                  It is made by e-on software and is available here as well as thier many other exciting products.
                                  Some of my 3d
                                    Krisidious
                                    yeah what the Devil said... it's got a free demo version that leaves a watermark. it's pretty simple but it pretty much requires that you buy this little SketchUp to Vue exporter it's like $25... but the landscaping that you put around your models is incredible... very life like. it has several different levels of software, all the same base really and then with different add-ons to make it more and more complete taking you from rendering single shots to making movies.
                                    you gotta see it to believe it.
                                    By: Kristoff Rand
                                      lucifer1101
                                      Sorry to derail your thread here but I just have to pick up on something
                                      I am not christian in any way so I don't believe in the devil, I am merely refering to lucifer of roman mythology, the "Morning Star where the name actually means "Shining One"
                                      And also all those out there that realate lucifer to being the devil, it is not mentioned in the new testament at all and only relates to a king of ancient Babylon..(One of the major accepted theories)
                                      Sorry about that I just dislike people who are quick to assume.
                                      Anyway carry on.
                                      I would love to see what you could come up with in Vue for this scene, it would be fantastic.
                                      Some of my 3d
                                      • F Offline
                                        flynbrians
                                        Krisidious thanks for the lead on the software. I will definitely give it a try and repost. Do you have any models rendered with Vue that you can post?
                                        And thanks to the other morning banter responses about heaven and hell. (well kind of) I always find it entertaining when a tread takes on its own life!
                                        • MarianM Offline
                                          Marian
                                          Continuing with the derailment of this thread... Not even Satan mentioned in the Old Testament is the devil, Satan means accuser and that Satan is actually an angel who tests people's faith for god.
                                          The concept of the devil has more to do with the Persians and Zoroaster who divides everything into only good or bad, no gray areas allowed.
                                          Anyway interesting project you have going on here flynbrians. 😄
                                            Krisidious
                                            btw I'm not a Christian or any religion so I have no problem with your name... and was not meaning anything by it. just being me..
                                            By: Kristoff Rand
                                            • 1 / 2
