    Keyboard Controls and Simulation stopping
    3 Posts 3 Posters 678 Views 3 Watching
      jblively
      Hello,
      Maybe i'm missing something, but there are 100's of great simulations out there using sketchy physics with keyboard controls. The problem I am having is that when I try to use most of them, the simulation stops when I press certain keys.
      For example, I'll run a tank simulation, and it will run just fine using the W key, but when I hit the M key, the Move tool gets selected and the simulation stops. Same with the L key which activates the Line tool.
      I know lots of people are using these keys and they wouldn't be using these keys if it always did this...so, I guess the question is, how do I stop the simulation from stopping when I press a key like, L,A,R,C or really any Key that is a sketchup shortcut key.
      I'm using a Windows XP system with sketchup 7.1, and sketchyphysics 3
      Thanks everyone!
      Joe
      • H Offline
        hpnisse
        Hello!
        There is two ways to get it work with keyboard.
        Simple:
        When you start the simulation there popup a window "SkechyPhysics Control Panel".
        Click on that so its active, then the keys will work.
        Less simple:
        Change the shortcuts to the tools.
        Click on: "Window" - "Preferences" - then "Shortcuts".
        Then change the shortcuts to whatever you want (or just delete them), tip!, add "ctrl" or/and "shift" key to the letter, then there is the same letter but you need to press "Ctrl" or "Shift" down at the same time.
        Just type in the tool-name ;that you want to change shortcut to; in the "Filter" box.
        Ex. of standard shortcuts:
        Q - Rotate
        E - Erase
        R - Rectangle
        A - Arc
        S - Scale
        L - Line
        C - Circle
        Hope this work (I know it do πŸ˜„ )
        And have fun with SP.
        /hpnisse
        ** %(#BF0000)[/hpnisse]**
        %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
          RogueInferno
          @hpnisse said:
          Hello!
          Simple:
          Less simple:
          Q - Rotate
          E - Erase
          R - Rectangle
          A - Arc
          S - Scale
          L - Line
          C - Circle
          /hpnisse
          I did the same thing, and it works.
          Red text
          Blue text
