    Saving components so they "open" nicely?
    4 Posts 2 Posters 446 Views 2 Watching
    • RichMorinR Offline
      RichMorin
      I have a plugin which saves the component it has been working on in a file, as:
      comp_def.save_as(out_path)
      All of the saved components import nicely, but some of them don't "open" well. For example, they might not show the entire model, show the model in too large a space, etc.
      In some cases, things get really extreme: I have to scroll waaaay out (or use "Camera > ZoomExtents") to see the model properly.
      I have tried doing a ZoomExtents inside the plugin, as:
      Sketchup.send_action('ZoomExtents;')
      or
        am    = Sketchup.active_model
        av    = am.active_view
        av    = av.zoom_extents
      or
      Sketchup.active_model.active_view.
        zoom(Sketchup.active_model.entities)
      but this has no effect on the saved file. HOWEVER, the window adjusts itself as desired if I open the saved file and type the command into the Ruby Console, as:
      Sketchup.active_model.active_view.zoom_extents
      My impression is that zoom_extents is working, but that the extents aren't getting saved by the save_as method.
      Help?
        jessejames
        Help?
        I don't know anything about saving components as i've never needed to do that, however there is somewhere a method like "update_thumbnail" or something like that? It might be useful to you...? If i find the correct method i'll edit my post. But remember i'm just purely guessing at this point πŸ˜‰
        Always sleep with a loaded gun under your pillow!
          RichMorin
          It looks like refresh_thumbnail does the trick; thanks! I'll report back when I have done further testing...
          -r
            RichMorin
            Indeed, it turns out that calling refresh_thumbnail after the call to zoom_extents and before the call to save_as clears up the problem.
