    [code] reading a CSV file
    5 Posts 2 Posters 3.3k Views 2 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Here's an example by Jim Foltz (he posted in GoogleGroups - Sketchup Developers),
      but modified, module and method wrapped.
      I (Dan) also added:
      • flexibility for a header row* setting a value delimiter in the method call.
      Returning CSV data as an Array of record Arrays
      Feel free to change the methodname to suit your taste.
      module MyTopLevelNamespace  #<--- you change this
        module MyPlugin           #<--- you change this also
          class<<self
            def read_csv_to_array(file,
                                  relapath='.',
                                  basepath=Dir.getwd,
                                  delim=',',
                                  header=false)
              firstline=true
              data=[]
              IO.foreach("#{File.join(basepath,relapath,file)}") do |line|
                if header && firstline
                  headrec = line.split(delim)
                  firstline=false
                else
                  record = line.split(delim)
                  data << record
              end # foreach
              return ( header ? [headrec,data] ; data )
            end # def
          end # class self
          begin
            dirNow = Dir.getwd # save current dir
            subpath = 'relative/path/to/data'
            Dir.chdir(ENV['USER']+'/somesubdir')
            records = read_csv_to_array('filename.csv',subpath)
            Dir.chdir(dirNow) # restore the dir
            # do stuff with array of record arrays
        end # module
      end # module
      If you set header=true, then the returned array will have 2 elements:
      • the 1st will be the header row array (1 record), * the 2nd will be an multi-record array (an array of record arrays.)
        Otherwise with the default (header=false,)
      • the method would return just an array of record arrays.
      EDIT: updated
      Reordered arguments to method, all but file with defaults:
      relapath (defaults to current dir ['.'])
      basepath (defaults to current working dir. [Dir.getwd])
      delim (defaults to comma. [','])
      header (defaults to false.)
      COMMUNITY CONTENT - Public Domain - Author claims no copyright.
      Moderators may edit post / correct code snippet(s) at will.
      I'm not here much anymore.
        Dan Rathbun
        Returning CSV data as an Array of record Hashes
            class<<self
              def read_csv_to_hash_array(file,
                                         relapath='.',
                                         basepath=Dir.getwd,
                                         delim=',',
                                         header=nil)
                firstline=true
                data=[]
                headrec=[]
                  if header.nil? && firstline
                    firstline=false
                  else
                    data << record
                end # foreach
                # use custom hash keys passed in header Array
                headrec = header unless header.nil?
                hasheddata=[]
                data.each do |rec|
                  rechash={}
                  headrec.each_with_index {|h,i| rechash[h.to_s]=rec[i] }
                  hasheddata << rechash.dup
                end # each rec
                return hasheddata
              end # def
            end # class self
            begin
              records = read_csv_to_hash_array('filename.csv',subpath)
              # do stuff with array of record hashes
          end # module
        end # module
        EDIT: updated
        header argument
        nil (Use firstrow from CSV file as Hash keys.)
        ['key1','key2',...] (Use Array strings as Hash keys.)
        header (defaults to nil.)
        • Z Offline
          zps222
          Hi, Dan, I simply paste "module MyTopLevelNamespace" in to Ruby console window of SU, but the error comes.
          Error: #<SyntaxError: (eval):978: compile error
          (eval):978: syntax error
          So why?
          By the way, can I use eclipse to run your code?
          Thank you.
            Dan Rathbun
            [code] reading a CSV file : FAQ
            Fequently Asked Questions
            1. What if I have string data that has embeded commas ??
            • Export your CSV from your spreadsheet using a delimiter other than comma. '||' or '$$' etc.* pass your custom delimiter to the method as the delim argument.
            1. How do I import from a TAB delimited datafile ??
            Call the method and specify 9.chr for the delim argument.
              Dan Rathbun
              @zps222 said:
              Hi, Dan, I simply paste "module MyTopLevelNamespace" in to Ruby console window of SU, but the error comes. So why?
              A module definition is a block statement. It's meant to be read by the interpreter.
              The console is a line evaluation function.
              You CAN make a module at the console by putting it all on 1 line, like:
              module Zps222; def say_hello(); puts "Hello!"; end; end
              YOU are supposed to choose YOUR OWNidentifier for a toplevel module name (namespace.)
              Replace "MyTopLevelNamespace" with a unique name that YOU decide. (You can use Zps222, or whatever you want, as long as it is unique for YOU, and noone else will use it.)
              Also "MyPlugin", you change it to whatever name you want your plugin to be.
              Yes. This code is not Sketchup specific. It's just plain old standard Ruby.
