    [code] loading from the Standard Ruby Libs
    2 Posts 2 Posters 1.4k Views 2 Watching
    • Dan RathbunD
      Dan Rathbun
      Ok, found a copy [of a Standard Ruby Lib file ] here: [...URL to Jim Foltz' webpage snipped...] if anyone needs it in the future.
      I don't really think Jim meant to be serving up Ruby Standard Libs for general use. For his plugin perhaps, but a well written plugin should first attempt to load the library from the user's standard Ruby install, and then only load a 'plugin packaged' version if the user's system does not have a full Ruby install.
      You can run into version mis-match bugs, etc.
      Code snippet:
      unless defined?(ExtendedRubyClassNameHere)
        begin
          # attempt to load from Std Lib
          require('extendedrubylibfile.rb')
        rescue LoadError
          # Woops! Load a plugin supplied copy
          require('pluginsubfolder/extendedrubylibfile.rb')
      You can get fancy and check the user's RUBY_VERSION, but really if the user has not installed a full Ruby install, they will be running v.1.8.0 (on Win32) and v.1.8.5 (on Mac,) so you might consider suppling v.1.8.0 & v.1.8.5 Ruby backup libs with your plugins.
      hhmm.. code would be::
        begin
        rescue LoadError
          if RUBY_VERSION=='1.8.0'
            require('pluginsubfolder/1.8.0/extendedrubylibfile.rb')
          else # prob on a Mac
            require('pluginsubfolder/1.8.5/extendedrubylibfile.rb')
      Sometimes the code in certain Ruby lib scripts does not change for many versions, so sometimes the choice is a bit simplier.
      COMMUNITY CONTENT - Public Domain - Author claims no copyright.
      Moderators may edit post / correct code snippet(s) at will.
      I'm not here much anymore.
      • K
        kwalkerman
        Dan,
        Very helpful, as always.
        So... For future... this is where you can download the library files if you need to: http://www.ruby-lang.org/en/downloads/
        Thanks again!
        Karen
