    No "Joint Properties" window
    3 Posts 2 Posters 614 Views 2 Watching
      markanthony
      Hello all,
      Just started with SketchyPhysics and for some reason when I right click a joint for the properties, I see it in the menu but when I click it it does not appear......
      any ideas????
      • W Offline
        Wacov
        I think the old 'Joints settings' thing is a remnant from the first version of SketchyPhysics that doesn't work any more but hasn't been removed. Just open up the UI (next to play/pause and restart buttons) and select the joint/group with joint in/group attached to a joint, and the joint will pop up in the UI. Click it there, and you can change the settings.
          markanthony
          Thanks!
