    If Toolbar is true make it false
    54 Posts 4 Posters 7.2k Views 4 Watching
    • S
      simonstaton
      I have managed to capture the event to hide and open the Getting Started toolbar:
      Sketchup.send_action(21992)
      Now I have this is there anyway to make it so that if the toolbar is open make it closed and if its closed leave it closed meaning that each time I start up sketchup or when its started for the first time it will hide the Getting Started.
      maybe somthing like this (obviously not this but the basics 😲)
      21992 = true {Sketchup.send_action(21992)}
      Thanks Guys,
      Simon
      • S
        simonstaton
        I just found the following in the Google SketchUp Ruby API
        status = UI.set_toolbar_visible("Camera", true)
        could I maybe change this to make what I want work?
        • thomthomT
          UI.toolbar_names
          http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#toolbar_names
          The toolbar_names method is used to returns the name of all the available toolbars (this differs between PC and Mac).
          > UI.toolbar_names ["Standard", "Principle", "Camera", "Drawing", "Edit", "Construction", "Walk", "DisplayMode", "StandardViews", "Section", "Google", "GettingStarted", "VCB"]
          • Dan RathbunD
            Dan Rathbun
            The PC world still wonders, what the differences are on the MAC.
            I'm not here much anymore.
            • S
              simonstaton
              status = UI.set_toolbar_visible("GettingStarted", true) didnt seem to work :s
              is there anyway to detect so maybe code like: "GettingStarted" = true { Sketchup.send_action(21992)}
              Apologies for my coding attempts I am used to javascript and not ruby πŸ˜„
              • Dan RathbunD
                Dan Rathbun
                You asked this same question back in August.
                http://forums.sketchucation.com/viewtopic.php?f=180&t=21156
                I Answered it (in the last post of that topic):
                ANSWER: Hide Toolbars On Load
                • S
                  simonstaton
                  that dosnt seem to work :s
                  • Dan RathbunD
                    Dan Rathbun
                    By the way.. the numeric arguments to .send_action are ONLY PC, you need to use the string args to be cross-platform (if that matters.)
                    • Dan RathbunD
                      Dan Rathbun
                      Close Sketchup, restart, open the 'GettingStarted' toolbar from the View > Toolbars menu. Then open the Ruby Console and try it again (paste it into the command box just as I had posted.)
                      Then tell us the result. (You may have corrupted something.)
                      • S
                        simonstaton
                        that should be fine as its only going to be run on pcs, damn macs πŸ’š
                        as the 'status = UI.set_toolbar_visible("GettingStarted", false)' dosnt work and the send action can open and close the toolbar, is there no way to pickup if GettingStarted is showing and if it is have it send action to toggle it off?
                        Simon
                        • S
                          simonstaton
                          no still nothing πŸ˜• how about my above method?
                          • Dan RathbunD
                            Dan Rathbun
                            @simonstaton said:
                            no still nothing
                            Check any code that is loading from the plugins folder, you must be corrupting something, because it DOES work.
                            You can try resetting the Sketchup UI to factory defaults.
                            Window menu > Preferences item
                            Preferences dialog > Workspace page > Reset Workspace button
                            • thomthomT
                              UI.set_toolbar_visible('GettingStarted', true) unless UI.toolbar_visible?('GettingStarted')
                              • Dan RathbunD
                                Dan Rathbun
                                yes sure
                                status = if UI.toolbar_visible?('GettingStarted')
                                which is the eqiuvalent of:
                                • thomthomT
                                  Oh - you tried that and it didn't work. Odd. See if Dan suggestion of resetting the workspace works. Becaus eI tested that snippet and it works.
                                  • S
                                    simonstaton
                                    no still nothing changes when I use that code either in the ruby console or in the .rb files and after doing what you said I am however using sketchup 6 if that could stop this from working?
                                    • S
                                      simonstaton
                                      I just tested this out in sketchup 7 and it does work fine so it must just be sketchup 6
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Don't know never used v6
                                        Why can't you upgrade to v7.1MR2 ?
                                        • S
                                          simonstaton
                                          some of the features I am using on my toolbar dont want to work in sketchup 7 😠 such as my checkout system,
                                          is it ok if I try detecting the toolbar being open? any chance you know any code that I could use to see if it is visible then using an if statement have it send the action.
                                          • thomthomT
                                            What doesn't work and why?
                                            I mentioned that here: http://forums.sketchucation.com/viewtopic.php?f=180&t=29216&start=0#p254562
                                            • 2 / 3
