    Inche fraction in ruby script
    7 Posts 4 Posters 1.2k Views 4 Watching
    • N
      nics
      hi guys, here's my code
      centerpoint = Geom::Point3d.new
      Create a circle perpendicular to the normal or Z axis
      vector = Geom::Vector3d.new 0,1,0
      vector2 = vector.normalize!
      model = Sketchup.active_model
      entities = model.active_entities
      edges = entities.add_circle centerpoint, vector2, 2.inch
      faceCircle = entities.add_face(edges)
      faceCircle.pushpull height
      however, I'd like to have 2 1/8 inches in the radius ... can I write it directly in the code and if so, how ? Otherwise, I guess I need to convert into a float number ? thanks
      • Chris FullmerC
        2 1/8 can easily be re-written as 2.125, so why not just write it like that? I'm guessing this is a question that is actually larger than just the example provided?
        Also, SU ruby works in inches, so there is no need to add the .inches to the end of the 2. But if you'd really like it to accept a fraction, you could write 2 1/8 as (2.0)+(1.0/8.0). That should be a workable solution. Good luck,
        Chris
        All my Plugins I've written
        • Dan RathbunD
          Dan Rathbun
          And also, of course, you may set your units in the Model Info dialog, Units page, to either Architectural or Fractional, (and choose precision,) if you wish the app UI to run in fractions.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            Yes. In Ruby (and in Math,) fractions are really just division.
            Again yes, you need to convert using the .to_f method, otherwise Ruby will truncate the fractional part and just return the Integer part (if both the numerator and denominator are Integer.)
            Here's an example:
            ` mod=Sketchup.active_model
            #Sketchup::Model:0x60aeb04
            ents=mod.entities
            #Sketchup::Entities:0x60a3434
            pt1=[12+1/8.to_f,14+5/8.to_f,0+7/8.to_f]
            [12.125, 14.625, 0.875]
            pt2=[33+1/2.to_f,67+3/4.to_f,47+3/8.to_f]
            [33.5, 67.75, 47.375]
            line=ents.add_line( pt1, pt2 )
            #Sketchup::Edge:0x602d1bc
            p line.start.position
            Point3d(12.125, 14.625, 0.875)
            p line.end.position
            Point3d(33.5, 67.75, 47.375)`
            • Dan RathbunD
              Dan Rathbun
              You can also use strings, and apply the Sketchup extension to the String class, which adds the .to_l method.
              Example:
              ` length = '5 3/8"'.to_l
              5.375`
              See the API (Base Classes): String
              http://code.google.com/apis/sketchup/docs/ourdoc/string.html
              • T
                todd burch
                Hi nics.
                You can use fractions pretty easily.
                entities = Sketchup.active_model.active_entities ;
                face = entities.add_face(entities.add_circle(ORIGIN, Y_AXIS, 2.125.inch)).pushpull 4.inch ;
                or
                face = entities.add_face(entities.add_circle(ORIGIN, Y_AXIS, '2 1/8"'.to_l)).pushpull 4.inch ;
                Note that there are many predefined constants for common locations/vectors you can use, and when it's not too cryptic for you, you can string commands together as well. Paste the above 2 lines into the Ruby Console and you'll get the same result.
                Todd
                • N
                  nics
                  wow thank you guys its really appreciated πŸ˜„
