    BoundingBox.intersect
    10 Posts 5 Posters 1.5k Views 5 Watching
    • DavidBoulderD Offline
      DavidBoulder
      Has anyone had problems with this. This is my first time using it, and I'm using it in conjunction with valid? to see if there are any points.
      What I've found is that if my two groups (in this case cubes) don't share any X-axis limits, then it correctly identifies if the objects touch or not. If however they have overlapping X-axis limits, it always returns "true" for BoundingBox.intersect.valid? even if the Y-axis and Z-axis limits don't overlap at all. If any of the three axes don't overlap the valid? should return "false" Below I took the code from the API sample and adjusted it to show two parallel lines that are running along the Y and then the X axis. They should both return false, but the pair along the X axis returns true.
      Any thoughts on this?
      Error 404 (Not Found)!!1
      (code.google.com)
       boundingbox1 = Geom;;BoundingBox.new
       boundingbox1.add [0,0,0]
       boundingbox1.add [0,100,0]
       boundingbox2 = Geom;;BoundingBox.new
       boundingbox2.add [100,0,0]
       boundingbox2.add [100,100,0]
       boundingboxA = boundingbox1.intersect boundingbox2
       puts boundingboxA.valid?
       boundingbox3 = Geom;;BoundingBox.new
       boundingbox3.add [0,0,0]
       boundingbox3.add [100,0,0]
       boundingbox4 = Geom;;BoundingBox.new
       boundingbox4.add [0,100,0]
       boundingbox4.add [100,100,0]
       boundingboxB = boundingbox3.intersect boundingbox4
       puts boundingboxB.valid?
      boundingboxA.valid? correctly returns "false"
      boundingboxB.valid? incorrectly returns "true"
      FYI - I have attached a screenshots of a simple example using two cubes where one returns true and the other false. Code above is similar but just two lines, vs. two boxes.
      ![This correctly shows boundingbox.intersect? as "false"](/uploads/imported_attachments/EJqD_intersectreturnsfalse.png "This correctly shows boundingbox.intersect? as "false"")
      ![This incorrectly shows boundingbox.intersect? as "true"](/uploads/imported_attachments/psx5_intersectreturnstrue.png "This incorrectly shows boundingbox.intersect? as "true"")
      Just a short followup. If I add the following code to each pair of lines here are the results
       puts boundingboxA.diagonal
       puts boundingboxA.height
       puts boundingboxA.depth
       puts boundingboxA.width
       puts boundingboxA.corner (0)
       puts boundingboxA.corner (1)
       puts boundingboxA.corner (2)
       puts boundingboxA.corner (3)
       puts boundingboxA.corner (4)
       puts boundingboxA.corner (5)
       puts boundingboxA.corner (6)
       puts boundingboxA.corner (7)
      8' 4"
      8' 4"
      0"
      0"
      (1000000000000000000000000000000", 0", 0")
      (-1000000000000000000000000000000", 0", 0")
      (1000000000000000000000000000000", 100", 0")
      (-1000000000000000000000000000000", 100", 0")
      false
      8' 4"
      0"
      0"
      8' 4"
      (100", 1000000000000000000000000000000", 0")
      (0", -1000000000000000000000000000000", 0")
      (100", -1000000000000000000000000000000", 0")
      (0", 1000000000000000000000000000000", 0")
      true
      David Goldwasser
      OpenStudio Developer
        Jim
        Seems like a long way from home. I would have thought the bb to be around the ORIGIN.
        I've never used the .intersect method - never realized it existed until now, actually.
          DavidBoulder
          I thought it was a long way from home as well. I thought it would be an empty bounding box without any points, so I didn't know what I expected corner 0 to return, I thought maybe "nil"
          By the way, here is what I get for points on a new empty bounding box.
          boundbox = Geom;;BoundingBox.new
          puts boundbox.height
          puts boundbox.width
          puts boundbox.depth
          puts boundbox.corner 0
          puts boundbox.corner 1
          puts boundbox.corner 2
          puts boundbox.corner 3
          puts boundbox.corner 4
          puts boundbox.corner 5
          puts boundbox.corner 6
          puts boundbox.corner 7
          boundbox.valid?
          Height, Depth, and Width return 0 (instead of the 8'4" that came up on my earlier example), but still large number for point coordinates. The 8'4" is the 100 inches, but I don't know how that ever got to be the height in the earlier example.
          0"
          0"
          0"
          (1000000000000000000000000000000", 1000000000000000000000000000000", 1000000000000000000000000000000")
          (-1000000000000000000000000000000", 1000000000000000000000000000000", 1000000000000000000000000000000")
          (1000000000000000000000000000000", -1000000000000000000000000000000", 1000000000000000000000000000000")
          (-1000000000000000000000000000000", -1000000000000000000000000000000", 1000000000000000000000000000000")
          (1000000000000000000000000000000", 1000000000000000000000000000000", -1000000000000000000000000000000")
          (-1000000000000000000000000000000", 1000000000000000000000000000000", -1000000000000000000000000000000")
          (1000000000000000000000000000000", -1000000000000000000000000000000", -1000000000000000000000000000000")
          (-1000000000000000000000000000000", -1000000000000000000000000000000", -1000000000000000000000000000000")
          "false"
          David Goldwasser
            Jim
            I can only guess, but do the large numbers mean infinite overlap in that dimension because that dimension has 0 length? (Or something like that.)
            • AdamBA Offline
              AdamB
              Are you using SU6? I seem to remember the intersect is broken in SU6.
                DavidBoulder
                Nope, I'm using current version of 7.1 on PC, I haven't tried on my mac PC at home.
                David Goldwasser
                  DavidBoulder
                  So if this is a bug here is my workaround may be to create similar results by using min and max points for the two bounding boxes being intersected. For my use I just need to know if they intersect, not what that resulting bounding box is.
                  This isn't code, just outline of what I'm thinking
                  Get min max for bounding box a and b
                  min a
                  max a
                  min b
                  max b
                  if
                  min ax < min bx < max ax or min ax < max bx < max ax
                  and
                  min ay < min by < max ay or min ay < max by < max ay
                  and
                  min az < min bz < max az or min az < max bz < max az
                   then bounding boxes intersect
                  else
                  they don’t intersect
                  David Goldwasser
                  • K Offline
                    kyyu
                    I used bounding box intersection in my Slots 4 Tabs plugin. How about using volume to see if they intersect?
                    b1 = sel[0].bounds
                    b2 = sel[1].bounds
                    bb = b1.intersect b2
                    puts bb.valid?
                    puts bb.width * bb.height * bb.depth
                      Jim
                      I see the same problem. It does seem like a clear bug. Align the boxes along each of the 3 axes, test for valid BB.intersect, and 2 of 3 alignments return valid, while the 3rd (along X) returns not valid.
                      • P Offline
                        PurpLev
                        I'm seeing the same problem, tested on both Mac and PC with SU 7.1.6
                        this is clearly a bug as the function does not do what it's name represents. although this would be renamed and used to find if 2 bounding boxes are within the same projected space.
                        I recently posted pretty much the same post here:
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=29156
