    Issue with objects moving through each other
    7 Posts 5 Posters 1.4k Views 5 Watching
      mtndewzero72
      Hi, I am a new user with sketchyphysics. So far, I have able to figure things out for the most part, but I was recently trying to build a car with a steering mechanism, and something went awry. I built a gear with servo joint and two more things on either side of the gear with more notches. The gear was supposed to turn and send one of the notched sticks one way, and the other the other way. It worked alright, but both the gear and the notched sticks began sinking through the body of the car slightly. I tried to steady all the pieces by attaching another servo to the gear and a few slider joints to the notched sticks. They no longer went through the floor, but now the notches in the gear and the sticks will partially ghost through each other. Things still work fairly well, but I wanted to solve this problem for good. I couldn't figure out what was wrong so I started all over. I built the steering mechanism first this time, paying the utmost attention to details. This time I tried to build a little "box" (I wasn't a true box, just something to hold the mechanism together.) around the notched sticks. When I started the machine, it first wiggled and then ghosted part-way through the box I had made and then the gear failed to turn the notched sticks at all. I figured maybe the first part had something to do with the edges of the notched sticks being on top of the edges for the box. I gave the mechanism room all the way around, but I got the same result.
      My question, then, is how I can get objects to become impassable to all other objects while still being able to move? I would love to know, any knowledgeable sketchup people out there. I appreciate your time.
      • H Offline
        hpnisse
        It would be helpfull with a upload of your model.
        It´s very easy, just post a new reply and click on "upload attachment" below the writing window.
        Then it would be very easy to understand your problem.
        /hpnisse
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          Davidfi1
          do you meen this : 4 Levels of Grouping http://forums.sketchucation.com/viewtopic.php?f=61&t=13702&p=207909#p207909
          or this : Revers Face issue http://forums.sketchucation.com/viewtopic.php?f=61&t=24201&p=206890#p206890
            mtndewzero72
            I tried two very different ways of building both models. The same problem exists in both. I would appreciate it if you could figure these out for me. Thanks.
            This was my first attempt. The problem is less noticeable.
              Davidfi1
              Did you look at what other people did?
              It worked for me.
              It could work for your model too.
              • EscapeArtistE Offline
                EscapeArtist
                I had the same issue.
                From this thread:
                Collisions can only be detected when an object is interesecting another in the given frame... if an object is moving fast enough to be on one side in one frame, and the other side in the next, no collision will be detected. There's a possiblity of raycast-collision detection being introduced, which will accurately detect collisions between objects at any speed.
                http://forums.sketchucation.com/viewtopic.php?f=61&t=17877&p=162369&hilit=detect+collision#p162369
                Don't know if it's the same problem as you are having, but hope it helps.
                • W Offline
                  Wacov
                  This is a simple mistake; basically, SketchyPhysics doesn't recognize the exact shape of the parts you have made (except in the 'special' case of the staticmesh, which cannot move). Instead, it essentially scales the selected physics shape to fit the bounding box of your group. To create complex shapes, with indentations, you need to combine simple shapes... for example, creating some grouped boxes, and then grouping them all together, keeping the overall group's physics shape set to 'default'
