    Post processing
    4 Posts 3 Posters 850 Views 3 Watching
      davidh
      Attached are 4 images of the same project using 3 different processing methods.The first 2 are rendered from twilight,brought thru fotosketcher and post processed in photoshop.
      the second is a straight render from vray with planting added in photoshop while the third is my attempt to try and create a HDRI style image from the vray render.this is not as successful as i would like because the original render is quite low in resolution and the process i use for the HDRI starts to breakup the pixels and it becomes obvious.But I do like the very sharp contrasts that are created.
      The first 2(image 1 was previously uploaded to the twilight render forum)have the same foreground,in this case a .png created and just dragged and dropped.I would normally do this at the start of a post-processing job just to get a feel for how the landsape planting would work.
        davidh
        One more of this project ,this time with some playful imagery
        • dermotcollD Offline
          dermotcoll
          I love them all - there is something very "Irish Country Farmhouse" about the building - it has alot of the elements of this type of dwelling on the rendered side of the building - I would love to own one. Images are all superb giving different atmospheres but each doing the job well IMHO.
          When you burn your arse - you gotta sit on the blisters!!
          • boofredlayB Offline
            boofredlay
            Great work David. I am very impressed.
            @davidh said:
            ...have the same foreground,in this case a .png created and just dragged and dropped.
            Would you be willing to share the png?
