πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Creating Components in Cab.rb
26 Posts 5 Posters 1.3k Views 5 Watching
    Dan Rathbun
    @frankn said:
    I had already tried that and it doesn't work, the only way to get them to show up is to edit the component then the preview shows up. Not a big deal but was just curious if I was doing something wrong with the script/code.
    Oh are these YOUR components ?? (ie, NOT Google supplied components,) that your having problems with?
    See API: ComponentDefinition.refresh_thumbnail
    cdefs = Sketchup.active_model.definitions
     cdefs.each {|comp| comp.refresh_thumbnail }
    I'm not here much anymore.
      Dan Rathbun
      Also..
      1. open the Model Info dialog.
      2. Go to the File panel.
      3. check the "Redefine thumbnail on save" option
      • F Offline
        Frankn
        [/quote]
        Thanks that worked perfect. πŸ˜„
        Frank
          Dan Rathbun
          @frankn said:
          I've also been looking into adding components to other components and all I found so far is some refernences to subcomponents and parent components but nowhere did I find how those work?
          ALL Sketchup::ComponentDefinition objects are kept in the model's Sketchup::DefinitionList collection. ALL of them, regardless of what level any instances ( Sketchup::ComponentInstance ,) of them are inserted.
          The "level" can at the top (under the model,) or nested many levels deep beneath any combination of Group / ComponentDefinition "parents".
          The Entity.parent() method is inherited (down thru Sketchup:Drawingelement ,) to all the objects that can be put into a model.
          So create all the component definitions you will use, and load them into the model.
          To nest a component into another, insert an instance of the subcomponent, into the entities collection of another component's definition.
          outer_comp_def.entities.add_instance( inner_comp_def, transform )
          .. repeat to suit (ie, you can insert multiple bolt & nut component instances, in another component definition.)
          P.S. (a Group is a "special" component, and so it also has a Sketchup::ComponentDefinition)
          • F Offline
            Frankn
            Hi Dan,
            Thanks for the explanation, I think that's what I did without realizing with just trial and error... many, many errors! πŸ˜„
            I thought you might like to see what I've been working on and by default bothering you with πŸ˜‰ so I included the script.
            Keep in mind this is a work in progress and my first attemp at at sort of programming so go easy on me. 😳 and please feel free to comment on what I'm doing wrong or that I could improve.
            Also the Drawers and Doors functions/inputs aren't implemented yet... still haven't figured that part out.
            Thanks again,
            Frank
            Test.rb
            • F Offline
              Frankn
              I fixed a few things and realized I could call the instances I added to the global component by different names. πŸ˜„ 😳
              It does run slow but I still haven't looked into optimising scripts so hopefully I can speed it up some though I don't mind it though, it's faster then creating a cabinet from scratch. πŸ˜„
              Next on the to do/ to learn list is...
              • Creating door and drawer fronts, creating drawers... shouldn't be a problem.
              • Add a user defined number of shelves and insert them evenly spaced in the cabinet... I can do this manually/individually but the math involved in doing them automatically should be fun to figure out!
              • Same thing for door and drawer fronts.
              • And give a choice of creating an upper or lower cabinet since the building of these is different... I could use 2 different scripts like I did when moding the cab.rb script but I think it would be slick having it all-in-one.
              • Add grain direction
              • And eventually learning how to export the to a csv file so that I can populate an existing excel spreadsheet that I use... yes I know there are already some cut sheet/list scripts but this is more of a hobby/learning experience and I'd like to see what I can do. πŸ˜„
              That should be it but I'm already happy with the progress I've made in just 3 or 4 days or learning this stuff.
              Again thanks for all the help I really appreciate your teach how to fish approach. πŸ˜„
              Frank
              Test.rb
              • 2 / 2
              2 / 2
