    How do you install Sketchy Physics?
    4 Posts 2 Posters 840 Views 2 Watching
    • I
      Involute
      I thought you just put it in the SU Plugins directory, but if I do that (with SU closed), then start SU, I can find no evidence of Sketchy Physics in SU (not under the plugins menu or view/toolbars). I'm running SU 7.1 Pro on WinXP Pro and downloaded Sketchy Physics2. See below for pic of my installation. Thanks.
        Curious that you have no files .rb at the root of the the folder Plugins ๐Ÿ˜ฎ
        • I
          Involute
          Is that where all this stuff is supposed to be? I thought plugins just had to be under the Plugins folder, not necessarily immediately under it; that subfolders were OK. Not so? Gets kind of messy otherwise, making it hard to remove things you don't use. How do you tell which entries apply to which plugins?
            I have not installed SKP3 but for the SKP2
            in my folder Plugins, Sketchyphysic.rb is at the root ๐Ÿ˜‰
            It's this one who call all the rest!
            Maybe you have unzipp all the file and obtain a level more of name folder?
