    Render this: Neon cube
    54 Posts 18 Posters 10.1k Views 18 Watching
    • soloS
      solo
      'Sketchni' aka Jeremy has been kind enough to donate his very cool model for us to play with.
      It is a neon cube light that can be posed in different ways.
      The cool thing is there is thick glass/plastic and neon lighting, making for a very interesting render challenge.
      I'd like to see as many different render engines as possible, most of all I'd like that whoever participates to have fun.
      The model: http://dl.dropbox.com/u/1129899/cube%20neon.skp
      http://forums.sketchucation.com/download/file.php?id=45624&t=1
      http://www.solos-art.com
      • soloS
        solo
        Looks like y'all are shy, so let me go first then.
        http://img707.imageshack.us/img707/1053/neoncubes.jpg
        http://img707.imageshack.us/img707/2999/neonx.jpg
        • S
          sketchnl
          Whow pete, you are really good. The surroundings looking good. πŸ‘
          What renderprogram you use? for this kind of productrenders, and the glass, is looking great.
          http://www.sketchimpressions.nl
          • soloS
            solo
            Thanks Jeremy, I use Thea.
            The scene is lit with IBL (hdri), I did not use glass, I assumed it would be plastic as flourescent light has very little heat.
            • chrisglasierC
              chrisglasier
              Is it possible to have these as direct attachments to SCF for the Imageshack blind.
              Would be appreciated, thanks
              With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
              • T
                timmy16744
                oh wow you took a very different approach to me pete, i envisioned this light as being a floor lamp not a desk lamp, although i love your renders. mine is currently rendering away so i should post mine later.
                • R
                  remon_v
                  looks very realistic pete, how long does such a render take? and is it unbiased?
                  • D
                    D-space
                    Probably it's a little high poly to cook fast. πŸ˜„
                    Nice renders and lovely looking plastics? Great start! πŸ‘
                    http://blibestmentalt.no/54981
                    • T
                      timmy16744
                      i didn't really want to be the one to follow pete, especially with the same render engine but oh well.
                      here is my crack with thea, i would have let it run for a bit longer but it took 2 hours to get to this point n i need to go to sleep πŸ˜›
                      oh and i have absolutely no clue what happened to that 1 panel that isn't lit, the materials are all the same....it's odd, i'm guessing i got some bad wiring and those lights need fixing.
                      • olisheaO
                        olishea
                        i was gonna say the glass table is very nice also!!
                        lovely work pete, excellent dof, very photographic!
                        oli
                        • david_hD
                          david_h
                          I jsut can't imagine why anyone would be shy with you posting Pete. πŸ’š
                          • L
                            lapx
                            Hey Pete that's very nice!
                            Is Thea your rendering of choice? Have you ever used Kerkythea? I thought you were a fan of Podium. It's nice to see you using Thea because I use Kerkythea which is similar from what I gather. It's nice to see good results are possible,even as good as Vray IMHO.
                            Is the table part of the HDRI or is it modeled?
                            • soloS
                              solo
                              Lapx,
                              I never really got into KT, never fancied the UI, Thea is easier to figure out and the material editor is better than anything I've used before.
                              I still have Podium and awaiting Version 2 to reach completion, I'm hoping that it will have some some key features I have been asking for for a very long time, so it's a wait and see.
                              Yeah, Thea is pretty damn fast for both biased and unbiased, and once you get your head around it's UI and figure out the material editor it becomes quite addictive actually.
                              The glass table is modelled, the background is HDRI.
                              • S
                                sketchnl
                                This is a render made with Vue. A little bit to much light, but in vue I need to play more with it. (btw. pete, do you know how to make hdri? And how can I put hdri in Vue, cause its not really works.)
                                • D
                                  D-space
                                  My first try...some close up....after a couple of hrs later.....πŸ˜‰
                                  • EarthMoverE
                                    EarthMover
                                    My first quicky with Vray. Low res output. Forgive the matrix looking wallpaper. I wish I had time to play more. This is a really cool model!!
                                    Content Creator at Skapeup
                                    • S
                                      sketchnl
                                      It's looking good. You use field of view?
                                      Is it a 12 volt? πŸ˜‰
                                      • S
                                        sketchnl
                                        Thanks, very cool, V-ray. 😎 .
                                        V-ray is to difficult for me, but you... I'm very impressed. πŸ‘
                                        nice work.
                                        • D
                                          D-space
                                          None of those! πŸ˜‰
                                          Thanks, and mine's still very much entry level...would love to do more for the lovely models. πŸ˜„
                                          • D
                                            D-space
                                            Nice matrix...definetly one of my fav movies! πŸ‘
                                            • 2 / 3
