    Render this: Neon cube
    54 Posts 18 Posters 10.1k Views 18 Watching
    • T
      timmy16744
      oh wow you took a very different approach to me pete, i envisioned this light as being a floor lamp not a desk lamp, although i love your renders. mine is currently rendering away so i should post mine later.
        remon_v
        looks very realistic pete, how long does such a render take? and is it unbiased?
          D-space
          @solo said:
          Looks like y'all are shy, so let me go first then.
          Probably it's a little high poly to cook fast. πŸ˜„
          Nice renders and lovely looking plastics? Great start! πŸ‘
          http://blibestmentalt.no/54981
          • T
            timmy16744
            i didn't really want to be the one to follow pete, especially with the same render engine but oh well.
            here is my crack with thea, i would have let it run for a bit longer but it took 2 hours to get to this point n i need to go to sleep πŸ˜›
            oh and i have absolutely no clue what happened to that 1 panel that isn't lit, the materials are all the same....it's odd, i'm guessing i got some bad wiring and those lights need fixing.
            • olisheaO
              olishea
              i was gonna say the glass table is very nice also!!
              lovely work pete, excellent dof, very photographic!
              oli
              • david_hD
                david_h
                I jsut can't imagine why anyone would be shy with you posting Pete. πŸ’š
                • L
                  lapx
                  Hey Pete that's very nice!
                  Is Thea your rendering of choice? Have you ever used Kerkythea? I thought you were a fan of Podium. It's nice to see you using Thea because I use Kerkythea which is similar from what I gather. It's nice to see good results are possible,even as good as Vray IMHO.
                  Is the table part of the HDRI or is it modeled?
                  • soloS
                    Lapx,
                    I never really got into KT, never fancied the UI, Thea is easier to figure out and the material editor is better than anything I've used before.
                    I still have Podium and awaiting Version 2 to reach completion, I'm hoping that it will have some some key features I have been asking for for a very long time, so it's a wait and see.
                    Yeah, Thea is pretty damn fast for both biased and unbiased, and once you get your head around it's UI and figure out the material editor it becomes quite addictive actually.
                    The glass table is modelled, the background is HDRI.
                      sketchnl
                      This is a render made with Vue. A little bit to much light, but in vue I need to play more with it. (btw. pete, do you know how to make hdri? And how can I put hdri in Vue, cause its not really works.)
                      http://www.sketchimpressions.nl
                        D-space
                        My first try...some close up....after a couple of hrs later.....πŸ˜‰
                        • EarthMoverE
                          EarthMover
                          My first quicky with Vray. Low res output. Forgive the matrix looking wallpaper. I wish I had time to play more. This is a really cool model!!
                          Content Creator at Skapeup
                            sketchnl
                            It's looking good. You use field of view?
                            Is it a 12 volt? πŸ˜‰
                              sketchnl
                              Thanks, very cool, V-ray. 😎 .
                              V-ray is to difficult for me, but you... I'm very impressed. πŸ‘
                              nice work.
                                D-space
                                None of those! πŸ˜‰
                                Thanks, and mine's still very much entry level...would love to do more for the lovely models. πŸ˜„
                                  D-space
                                  Nice matrix...definetly one of my fav movies! πŸ‘
                                    D-space
                                    @urgen said:
                                    ..night HDRI.....hypershot 20 min..... +photoshop
                                    Lovely hypershot! πŸ‘
                                    Some emitting materials? How about posting it?
                                    It's not needed if it's some xray from the lib. πŸ˜‰
                                    Lovely reflections massimo! πŸ˜„
                                      sketchnl
                                      uhu really nice reflections πŸ‘
                                      • massimoM
                                        massimo Moderator
                                        Thanks D-space and sketchnl. πŸ˜„
                                        BTW your model is really good jeremy. πŸ˜‰
                                          D-space
                                          Just a couple more shots...xmas ornaments & photomatch. πŸ˜‰
                                          • urgenU
                                            urgen
                                            ...yes=))) this is emitting material ....It there is ...But it is not made active in standart hypershot πŸ˜’
                                            http://img340.imageshack.us/img340/714/www9742695.gif
                                            http://img255.imageshack.us/img255/1857/380c.jpg
                                            --pupil forever...------
                                            • 1 / 3
