    Neon cube orichami (respons) and update2
    9 Posts 5 Posters 1.1k Views 5 Watching
    • S
      sketchnl
      free expression.
      after minutes playing with paper is this the result
      http://www.sketchimpressions.nl
      • F
        fymoro
        Great model, it should be cool to have a render image... 👍
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        • S
          sketchnl
          this is the render images. Its to bad mine
          preformeces are to low to put the lights on.
          render image orichami cube
          • soloS
            solo
            Jeremy
            I really like this model, very cool concept.
            If you want to share the model I can make it available for a 'render this' challenge for all to try using different render apps.
            http://www.solos-art.com
            • majidM
              majid
              I've experienced KT, V-ray,podium, Twilight, and Thea regularly .in case of kt and Twilight suggest you to use unbiased presets like MLT, or BiMLT , if you are adding an emitter material to the neon parts (as I've experienced that how much light you have in your scene doesn't effect rendertime on those presets) , v-ray is also good with emitter materials, while those sort of material are really killer for poduim (in general). also you may find that Thea is a good choice
              • S
                sketchnl
                Thanx for your response. This image is made in kerkythea. but mine prefomeces are to low. Cost me more than 14 hours.
                • S
                  sketchnl
                  @solo said:
                  Jeremy
                  Whow I feel very honoured. What's the meaning of this challenge. Do you know, what program can I use for the lights. How can I post the model.?
                  • S
                    sketchnl
                    here is a new render with vue
                    • U
                      Ultimatez 32
                      @sketchnl said:
                      @solo said:
                      Jeremy
                      Hi sketchnl,
                      You post the model using the upload attachment bar at the bottom of the posting page.
                      ultimatez
                      Windows 7 64-bit, Intel Core i3 M350 @2.27GHz, nVidia GEFORCE 310M 512Mb with CUDA, 4gb RAM
