    Download to Sketchup button
    29 Posts 4 Posters 5.3k Views 4 Watching
    • E Offline
      ericschimel
      So I have created a website that I am going to host some components on. I have a Ruby plugin that I wrote that opens my website in Sketchup. What I am having trouble figuring out is how to get Sketchup to have the models inserted into the model rather then downloaded to the computer.
      I want my "download to model" button work just like the 3D Warehouse button works...
      I have seen this done before, but try as I might, I can seem to nail this one, does anyone out there have any suggestions?
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • Dan RathbunD Offline
        Dan Rathbun
        I want my "download to model" button work just like the 3D Warehouse button works..?
        see...
        http://code.google.com/apis/sketchup/docs/releases.html
        What's new in SketchUp 7.0 M1
        Load Definitions from the Web, or Save to Disk
        • Ability to download a definition from URL
        model.definitions.load_from_url(url, download_handler)
        • Ability to Save components to disk from the API
        my_definition.save_as(path)
        For more info on DefinitionList.load_from_url (including a prototype download_handler,) see:
        http://code.google.com/apis/sketchup/docs/ourdoc/definitionlist.html#load_from_url
        For info on ComponentDefinition.save_as, see:
        http://code.google.com/apis/sketchup/docs/ourdoc/componentdefinition.html#save_as
        I'm not here much anymore.
        • E Offline
          ericschimel
          Thanks so much for the prompt reply!
          Here's the deal though, I am REALLY Ruby illiterate...
          Basically, I was barely able to create a plugin that opened a website in Sketchup, and I was only able to do this by MUCH trial and error...
          So that Ruby code sample you gave me seems to be exactly what I need, according to the description. Where do I place the code? In my plugin that opens the web window in Sketchup, or is there some of that code that needs to go in my actual website where the components are?
          -Eric
          Custom Models
            Dan Rathbun
            Sketchup Ruby is client side. (It does NOT go on the website.)
            Actually I did notice a few errors in that sample code. It could be cleaned up and better implemented.
            Well you'll need to take some time and get literate, or run the risk of having your code collide with other plugins, possibly making users angry.
            or..
            Check the script libraries for something similar, that you can tweak and customize for your own use, (which is one way to learn more quickly.)
            or..
            If you don't have the time, you can hire someone experienced, to write it for you, or cleanup your code.
            • E Offline
              ericschimel
              Well, I think I may hire someone to do this for me, I am just trying to get a "Proof of concept" going so I can test out its functionality, and then pass it on to the real programmers to make perfect.
              I have found plenty of examples of the web dialog being implemented, thats how I was able to pull that off. I haven't been able to find any examples of where someone has opened a web dialog and sent a model into Sketchup from a website.
              You saying that the example is buggy makes me not feel so warm a fuzzy about learning off of that example, I'd rather see one that works.
              -Eric
              Custom Models
                Dan Rathbun
                Eric, The 'bugs' are not that bad:
                read this thread, it is an example of one of the 'issues' with the API
                sample (it's not module wrapped.)
                http://groups.google.com/group/sketchupruby/browse_frm/thread/4f22a3a...
                below 'class LoadHandler', add this line:
                attr_reader(:error)
                in 'method onFailure', make this change:
                rename $last_error to @error so the line reads:
                @error = error_message
                now the if statement will work correctly.
                The whole thing (for YOUR plugin, plus any other code) needs to be wrapped in a module SketchTHIS block. You MAY have nested modules and classes inside your Top Level Namespace (SketchTHIS.) If you plan more than one plugin, that works with your site, OR is 'site-branded' each should be (or end up in,) in it's own submodule, beneath the outer namespace SketchTHIS. Read the post at Google Groups to see how to use file spanning. (It means even if you don't know what the next plugin will be named, or how many you may end up with; each will be protected from each other in their own namespace; all will be protected from the rest of the Ruby plugin world.)
                NOTE, that for module and class names, Ruby may not allow the use of a '!' character; it's kind of reserved for method names and a form of the not operator, (as in !=) 'not equal to'.
                **You might have missed the fact that the use of a LoadHandler class object is optional.
                You can always just use (for testing):
                Sketchup.active_model.definitions.load_from_url("myurl/comp.skp")
                within the WebDialog callback method, that executes when the user clicks the "download to model" button. (The filename part of the url string changes of course, depending on the file.)
                The component is added to the InModel Component List, but an instance is NOT added to the actual model. (The user would need to drag&drop into the model, in the normal way of adding a component instance to
                the model.)
                I think that's what you are after?
                • E Offline
                  ericschimel
                  I think this is what I am after...
                  I am good with the Ruby code, where I am confused is how to implement this on the server side. If I have a hyperlink to a file, what has to happen for Sketchup to insert, rather then download the model?
                  -Eric
                  Custom Models
                    Jim
                    using load_from_url puts the download in the Component browser. You then need to place an instance in the model using either Model.place_component or Entities.add_instance.
                    • E Offline
                      ericschimel
                      I understand that, I did find those commands in the Ruby docs, my question is this:
                      Those commands, from what I understand, need to be generated when the user clicks on a model. How do I make that happen? A standard hyperlink won't do it....
                      -Eric
                      Custom Models
                        Jim
                        For that to work, your user needs to be viewing your web page in a WebDialog opened from SketchUp.
                        The hyperlink does not href the model, but rather it might look something like the following, although it could be any element not just an anchor.
                        <a href="#" onclick="skp;download_model@modelname.skp">Download Model</a>
                        or
                        <span onclick="skp;download_model@model_url>Download This</span>
                        which calls the WebDialog callback named "download_model" and passes in the filename.
                        # Then in the Ruby plug-in;
                        @dialog.add_action_callback("download_model") { |dlg, args|
                          Sketchup.active_model.definitions.load_from_url(args)
                        In a nutshell, the html code sends the model name or url to the Ruby plug-in, which then uses load_from_url to download the model.
                        • E Offline
                          ericschimel
                          Aha! That was the thing I was looking for! Now that I know how to send commands down to Sketchup through the web dialog, I can start experimenting!
                          I'll let you know how it works for me...
                          Thanks so much!
                          -Eric
                          Custom Models
                          • E Offline
                            ericschimel
                            Ok Jim, I used your code exactly as you posted it. The method I used in my webpage was your "href" method. The only thing I changed was switching "modelname.skp" for "test.skp" which is a Sketchup model of the same name that I have in the same directory as the web page.
                            I am getting a script error whenever I load the web page in Sketchup. The error, near as I can tell, points to the ":" in the command. Why? I have no clue... Perhaps there needs to be some additional code in the HTML of my web page? Right now the only code in it at all is the "href" command.
                            See attached file for the screenshot of the error.
                            By the way, I added the code exactly as you posted it into my Ruby code. Sketchup seems to like it so far, I suspect that the script error I am getting has nothing to do with the Ruby code, as I don't think the Ruby has even been used yet, because of the error in the web page.
                            > or
                            -Eric
                            Custom Models
                              Jim
                              Because I made a mistake! 😳
                              onclick="window.location='skp;download_model@modelname.skp'"
                              • E Offline
                                ericschimel
                                Thanks Jim for correcting it... Now I can load the page with no script errors.
                                I am having an issue with the Ruby code I think... I haven't seen any Ruby code with an "@" symbol in front of it, so I tried it with, and without, and I still not getting any results.
                                I checked with the Ruby console, and there seems to be an error with the "add action callback" line. Should it matter where in the Ruby I place the code? and what other code is in there? Currently, all my Ruby does is open a web dialog first, then the "Add action callback line is in there" and then there is the code to place an icon in its own toolbar, and in the "plugins" menu. That's it.
                                See the screenshot for the Ruby console...
                                Once I see this working one time, I should be able to get things moving on my own....
                                -Eric
                                Custom Models
                                  Dan Rathbun
                                  Well, Jim doesn't realize how much your a spankin'-newbie at Ruby.
                                  In Jim's example the '@dialog' refers to YOUR WebDialog instance reference name, whatever it is you chose to name it in the constructor statement (example):
                                  @dialog = UI::WebDialog.new( ..*parameters*.. )
                                  IF you named it "SketchTHISdlg", then your constructor statement should look something like ( with proper parameters, of course.):
                                  SketchTHISdlg = UI::WebDialog.new( ..*parameters*.. )
                                  then the block to create the callback method, would be (like):
                                  # Then in the SketchTHIS Ruby plug-in: SketchTHISdlg.add_action_callback("download_model") { |dlg, args| Sketchup.active_model.definitions.load_from_url(args) }
                                  Both Jim and I are hoping you have wrapped your plugin within a module, and this is why Jim used an instance type reference (' @dialog'); my example uses a module constant (' SketchTHISdlg'); both can work, or you can use a module/class reference that begins with @@, as in ' @@mydialogname'.
                                  • E Offline
                                    ericschimel
                                    Ok, so if I understand this correctly, the "add action callback" command needs to know what window the commands are coming from. So, when you create a web window, you name it. Naturally, the "add action callback" would need to have the same name as your window. That makes sense to me, if I am reading everything correctly.
                                    So, I went ahead and switched the name that Jim gave me as a filler name, and put my dialog name in, and it still doesn't work. In the Ruby console I am getting a "uninitialized constant" error.
                                    As far as wrapping stuff up in modules, I think I understand the concept of that, but at this point, I think its way over my head... πŸ˜„
                                    Here is the entire ruby script I am using:
                                    require 'sketchup.rb'
                                    def create_dialog
                                    	dlg = UI;;WebDialog.new("SketchThisNET", true, "", 1200, 800, 150, 150, true);
                                    	dlg.set_url "file;///C;/Users/Eric/Documents/SketchThis/TEST2.html"
                                    	dlg.show
                                    	SketchThisNET.add_action_callback("download_model") { |dlg, args|
                                    if( not file_loaded?("SketchThisNET.rb") )
                                        add_separator_to_menu("Plugin")
                                        UI.menu("Plugin").add_item("SketchThis.NET") { create_dialog }
                                      toolbar = UI;;Toolbar.new "www.SketchThis.NET"
                                         # This toolbar icon simply displays Hello World on the screen
                                         cmd = UI;;Command.new("www.SketchThis.NET") {
                                           create_dialog
                                         cmd.small_icon = "SketchThisSmallIcon.png"
                                         cmd.large_icon = "SketchThisLargeIcon.png"
                                         cmd.tooltip = "www.SketchThis.NET"
                                         cmd.status_bar_text = "www.SketchThis.NET Toolbar"
                                         cmd.menu_text = "SketchThis"
                                         toolbar = toolbar.add_item cmd
                                         toolbar.show
                                    file_loaded("SketchThisNET.rb")
                                    -Eric
                                    Custom Models
                                      Dan Rathbun
                                      Eric, on you on a PC or a Mac?
                                        Dan Rathbun
                                        Ok.. homework assignment time. Your homework is to go and read this tutorial:
                                        Ruby User's Guide
                                        • E Offline
                                          ericschimel
                                          I am on both the PC and the Mac. I am mostly working on a PC though.
                                          So did I miss something obvious on my current situation, or will I find the answers in the users guide? πŸ˜„
                                          -Eric
                                          Custom Models
                                            def create_dialog
                                               dlg.show
                                            When you create your webdialog
                                            dlg = UI::WebDialog.new("SketchThisNET", true, "", 1200, 800, 150, 150, true);
                                            here, the variable dlg is your reference to the webdialog. This is what you must use to refer to the dialog.
                                            Later on when you do SketchThisNET.add_action_callback("download_model")
                                            This is incorrect. It should be dlg.add_action_callback("download_model")
                                            I take it that you tried to refer to the webdialog by using the title you assigned the webdialog window when you created it?
                                            • 1 / 2
