    Trouble with forklift.
    2 Posts 2 Posters 391 Views 2 Watching
      Mezillious
      Ok, new problems. I've attached a forklift I am creating, i am trying to make the vehicle move using controlled hinges because I want it to move forwards and backwards. My problem is, that whenever I try to adjust a setting that SP apparently does not like (example - rename servo6149 to servoarm2) it doesn't apply my changes and the next time I click on the UI button, nothing comes up, no matter what part of my model I have selected. The only thing I have found to fix it is close the program and restart it.
      Any clues on how to avoid this?
      Also, is there a list of controllers available for SP3? I know of slider('x') and key('x'), are there any others, or even better, a document listing them?
      Thanks,
      Mez
      forklift.skp
        Anthony R
        Your right it certainly doesn't like it. I'm sorry I can't help you with this as I'm a real new to this but I'm surprized that no one else has been able to give you some insight.
