    Selection start/end detection
    4 Posts 3 Posters 298 Views 3 Watching
    • Y Offline
      YamaArashi
      Hello Ruby noob alert πŸ˜„
      I manually draw a line with the pencil tool and select it. If I then have a script with the code below the variable selection contains my line,I know because the clear deselects my line on the screen. My question is how do i get the start and end points of the selected line? I have been reading the google api site, but tbh the code examples are very fragmentry and putting stuff together is hard.
      model = Sketchup.active_model
      selection = model.selection
      selection.clear
        Jim
        I made this mistake just yesterday (with def), but end is a Ruby keyword and not such a good name for a variable.
          cjthompson
            cjthompson
            A "Selection" is a collection of entities (lines, faces, etc.)
            In order to get the line, you have to get the first object in the Selection, since you only have one thing selected:
            line = selection[0]
            Then, once you have the line, you can get the start and end vertices like this:
            vtxStart = line.start vtxEnd = line.end
            To get the positions of the vertices, just type either: startPosition = vtxStart.position or endPosition = vtxEnd.position
            Hopefully this is clear enough to get you started.
