    How to get a selected object center?
    3 Posts 2 Posters 239 Views 2 Watching
      Mcdull
      I Want to get a object center point, the object may be a mesh,face,or group.my method is
        UI.add_context_menu_handler do |context_menu|
         context_menu.add_separator
         context_menu.add_item("center point") {
          model = Sketchup.active_model
          entities = model.active_entities
          first_entity = entities[0]
          bbx=first_entity.bounds
      #    selection = model.selection
      #          selection.each { |entity|
      #              $boundbox = entity.model.bounds
      #              UI.messagebox($boundbox.corner 0)
      #               UI.messagebox($boundbox.corner 1)
      #  puts selection.count
      #  puts $boundbox.center
      puts bbx.center.to_s
      but the result is always the same,would tell me why? thank u
      • Chris FullmerC Offline
        because you are finding the bounding box for the first entitiy in the list of entities. What you want is to find the bounding box of the first entitiy in the selection set I would bet.
        model = Sketchup.active_model sel = model.selection first_entity = sel[0]
        try that
        All my Plugins I've written
          Mcdull
          try that
          i got it ,thank u
