    Bind keys without providing a "shortcut"
    1 Posts 1 Posters 248 Views 1 Watching
    • A
      alz
      Is this correct or incorrect?
      The only way to bind keyboard shortcuts is:
      • by exposing it as a plugin action
      • by describing it within a plugin tool
      The problems:
      • If done via a plugin action, each desired shortcut needs to be have a dedicated plugin listing.
      • If done via a plugin tool, that tool needs to always be active to have the shortcut be active. But within SketchUp, you can only have one tool active at a time, which means the shortcuts would turn off if a different tool was used.
      Or, am I overlooking something obvious?
      Off-topic --
      Is there a way to suppress / remove native Content Menu entries?
